HardHitter
06-08-2013, 01:22 PM
I've been starting to get into muscle cars recently and was looking into 1970-1973 Camaro's initially. Then I found a 1967 Firebird and started looking into those.
I ended up taking a look at a 1968 Firebird today and I'm trying to spend 10-15K on a budget to give me a good cruiser for now. I want to make sure that the body has little to no rust as that is my main concern since I know body work can add up.
From a view standpoint there was no rust spots that really stood out. I checked the floors (looked under the carpet), inside the fenders, the bottom of the fenders, under the car, etc. I was able to spot some potential rust by the door jams. You can take a look at the pictures and let me know if there is anything you think looks peculiar.
The car needs new brakes or something because I felt like I was full pushing down on the brakes and it would barely start to break. He said that the brakes may needs to be bled.
Car Specs:
The motor is an 04 6.0l (LQ4) from a heavy duty 4x4 Silverado 2500. Motor was cleaned up by Valley Balancing. Comp cam XR275HR and 318 beehive springs were also installed by the same machine shop. The intake is a GM Performance single plane. The ignition is MSD 6LS BOX and js currently operating with a #4 pill timing. The headers are Dynatech aluminum and that are ceramic coated..
The transmission is a 700r4.. All hi performance parts.. Heavy duty clutches and hard gears, Corvette servo and re programmed Valve body. The tranny was rebuilt less than 1k miles.. 2400-2600 stall converter.. Limited slip differential with 3:42 gears from an early 70's Trans-am... All bushings are red polyurethane, Energy Suspension brand.. The subframe connectors are Global West brand.
I'd love to hear your insight on the car and how much you think I should offer for it if I want to go forward with purchasing.
https://static1.pt-content.com/images/pt/2013/06/IMG_20130608_082625_zpsdf4e8540-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_20130608_082800_zps4c3ca256-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_20130608_082919_zpsc7f295b0-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_20130608_083150_zpsf7061ba7-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_20130608_083120_zps9e03c57c-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_20130608_082811_zpsaab30d6e-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_20130608_082829_zps0d8d2743-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_20130608_083304_zps59b126be-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_20130608_082638_zpse30fb315-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_20130608_083139_zpsf6de7fd2-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_20130608_083224_zps6e42efe5-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_20130608_082837_zps21e8d8a6-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_20130608_082747_zps9ec25385-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_20130608_082907_zpsb4eeff80-1.jpg
Car Specs:
