View Full Version : BBC Procharger
kidreynolds
08-21-2005, 08:12 PM
I have a nice 454 bbc (10:1, stock rods arp bolts, steel crank) We just built the motor not long ago and I was thinking about adding a procharger. Is this a bad idea (Do I need to beef up the bottom end) or is it possible to run a procharger on this setup without tearing anything up
WELTERRACER
08-22-2005, 10:58 AM
with that high of compression you would only be able to run 6psi if you have aluminum heads and it would be suggest that you use an intercooler..
You are not at all crazy..
kmcanally
08-22-2005, 02:53 PM
he speaks from experience!
WELTERRACER
08-25-2005, 03:39 PM
Ya.. mine went KABANG... with 10psi and 10.3 compression.. LOL
Im now running 9.0 with 10psi
