View Full Version : Swap LQ9 TB to LS6 TB
RamAir
06-01-2013, 01:04 PM
Does anyone know if it is possible to swap the LQ9 TB to LS6 TB without change the ETC?
M
andrewb70
06-01-2013, 01:30 PM
M
I don't believe so. The Corvettes used their own specific TAC module for the pedal.
RamAir
06-01-2013, 11:26 PM
Do you know what is different between the modules? The thing is that I have a LQ9 with the Corvette serpetine drive and the LQ9 TB motor interfere with the belt tensioner. My plan was to swap to the LS6 TB but i does not work. Anyone know if I can swap the TPS and TB-motor from the LQ9 to the LS6 TB.
analyte
06-02-2013, 03:04 PM
The connector is different as well since more is built in the LQ9 TB.
Why the change? There is no size difference so I don't foresee a performance improvement.
Kerry
RamAir
06-02-2013, 07:05 PM
The connectors are the same, I have connected the LS6 TB to the car but it is not responding. Kerry, It is not for the performance, the TB motor interfere with corvette belt tensioner.
analyte
06-02-2013, 09:00 PM
Sorry, I thought I had read the connector was different between can and trucks. What pedal and tac are you using with the Vette tb?
RamAir
06-03-2013, 12:36 AM
TAC from Cadillac Escalade 2002 (same as engine) pedal probably also from Cadillac.
