View Full Version : Gen 1 Camaro Subframe with Front Mount Set Up and Oil Pan Notch - Value?
ADiCarlo
05-28-2013, 11:23 PM
I'm trying to find out if a gen1 sub frame that has been welded with a notch for the oil pan and a Moroso front engine mount set up has any value?
I'm about to do a LS swap and will not be using the the front mount set up so I'll be cutting it off. Also does the notch affect the strength of the subframe - its been reinforced with square tube.
Any insight into this set up would be great as I've never seen or worked with it before. Should I sell it or swap for a factory set up? I would hate to cut up something that has all this hard work in it.
Also FYI this is located in Los Angeles CA.
AD
https://static1.pt-content.com/images/noimg.gif (http://s761.photobucket.com/user/adicarlo86/media/20130421_163651_zps546990f3.jpg.html)
ADiCarlo
06-16-2013, 07:50 PM
Any ideas guys?
MarkM66
06-27-2013, 03:48 AM
Just use it.
