ChainDrive
05-28-2013, 09:19 PM
Hey All, This is my first post here, but I'm a regular on FBBO - known as GRabinov911. I copied this post from over there because lotsa folks there suggested I talk to you guys. Thanks in advance.
Post 1: OK so a buddy of mine ran the Silver State Classic (in a 65 Mustang) and I can't get it out of my head!
My 1970 Plymouth Roadrunner resto has been going along great and the car runs well on the stock 383 (only 50k miles) and the 3.23 rear end. I've got it all set up with Firm Feel suspension parts because I'm a handling geek - not so much because I thought I needed then, but maybe I do...
I just bought, magnafluxed and sonic checked, standard bore, 1978 440HP block to use to build a new motor for the car. Again, not cause it NEEDS a new one, but because I've never built a car engine before (done motorcycles) and I've always wanted to. I have a local machine/hot rod shop to help me with the build. They are used to building hot rod "drag" engines, and they build some pretty hot inboard boat engines.
Question: If I want to build my 440 for roadracing, or going really fast (about 100mph average) in a relatively straight line over a long distance (90 miles), what do I tell my hot rod shop guy about cam selection, compression, carb specs, etc.? I'm guessing this is a somewhat different engine than one build to run for 11 seconds from idle to 8,000 rpm, more like a boat engine which runs high rpm under heavy loads for long periods of time...
Post 2: I'm back with the Road Racing Engine thread. My stock 440 block is now at the machine shop with a Mancini Racing internally balanced 493 stroker kit sitting next to it - a complete short block rotating assembly ready to go together. Now we're talking about cams and types of cams. The shop is a fan of Crower cams (they say they like the billet they are made from) and recommends going with a hydraulic roller setup. I'm not opposed to either for any reason that I know of. I don't mind the ease of maintenance of a hydraulic. I don't mind the limited RPM (6,500 or so) because I don't expect to be above there anyway with my setup (now a 3.55 TrueTrac rear end, 727 auto trans / 2,500 RPM stall converter, 27-28" tire) . Crower doesn't have a stock Chrysler 440 hydraulic roller cam in their catalog, but the machine shop suggests going with a custom grind.
I spoke to them about the oil clearance issue and they have no problem with that because they build boat motors all the time. The problem is, the shop guy keeps telling me: You're not gonna find a cam that is good for sustained "high RPM" road racing and still comfortable on the street. To refresh your memory, what we are trying to build here is an engine that will hum along comfortably at 4,000 to 5,00 RPM, which is what it takes to go 100+ in a 3.55 Roadrunner for an hour or more.
Now I didn't tell him I need maximum horsepower at 4,000 to 5,000 RPM. I just need SUSTAINED operating at 4,000 to 5,000 RPM with enough horsepower to maintain the high speed over varied highway terrain. I know that I can keep my Roadrunner at 100+ MPH on just the stock 335HP that my 383 makes (less, since it DEFINITELY doesn't make 335HP in its current condition). So that means that as long as the motor makes 300 to 400HP between 4,000 and 5,000RPM. I'm good to go.
It can't be THAT hard to come up with a cam profile that will do that and still be streetable right? (I'm planning on standard Edelbrock performer RPM 84cc heads, my existing Schumacher tri-y headers, good ignition and some big carb.). It'll probably be closer to 450+HP in that range I'd guess. Obviously the car will spen more time on the street trolling around than on the "track" at 100+MPH.
Here's a proposed grind based on a Lunati cam from Mancini:
Item# LUN60304LK
$218.95
Product Description
Hydraulic. Hot Street cam, likes 2800 converter, Hi-Rise type dual plane intake with 850cfm carb, headers, 10:1 compression and 3.73 gears. Likes up to 200HP nitrous.
Advertised Duration (Int/Exh): 276/284
Duration @ .050 (Int/Exh): 234/242
Gross Valve Lift (Int/Exh): .513/.533
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2200-6400
Anyone care to check my calculations and my logic? Be gentle!
Greg
Item# LUN60304LK
$218.95
Product Description
LSA/ICL: 110/106
Greg
