View Full Version : Factory GM rag joint ???
70TWO NOVA
05-25-2013, 03:00 PM
Hey guys, I'm having an impossible time finding a factory GM rag joint for a second gen Camaro (1980 camaro z28) I've bought the ididit universal one....way too big with wrong hardware. I bought the Detroit speed one.... Came assembled and looks nice, but still way too big. I swear I've searched everywhere and can't find one. With the popularity of these cars you would think this would be an easy part to find. All I'm looking for is a bone stock factory rag joint. Does anyone know where I can get one???
redfire69
05-25-2013, 03:50 PM
Check out Ricks Camaros, they have stock replacements...
70TWO NOVA
05-25-2013, 04:38 PM
I actually ordered one through them, it's the "universal" repair kit from ididit. Way too big with wrong hardware. These things are soo hard to find
CarlC
05-25-2013, 07:07 PM
I thought it was posted in PT but I must have overlooked it. http://www.lateral-g.net/forums/showthread.php4?t=39632&page=5
Basically, I did not like the Ididit part at all, and the factory/DSE part would not mate since the spline on the new column was not the same as the factory part. So, I took parts of both and made a Frankenstein part that is far better.
70TWO NOVA
05-25-2013, 08:24 PM
Thanks , I'm glad I'm not the only one going through this issue
newsshooter23
05-25-2013, 08:53 PM
Try National Parts Depot?
LeighP
05-27-2013, 07:24 PM
Call Dave at Pro-touringf-body.com - (you'll have to google the website)
He'll probably be able to help you...pretty much knows it all for 2nd gen F-body suspensions / steering.
novaderrik
05-30-2013, 03:36 AM
isn't that what the Dorman 31011 rag joint that is used to put later model (IROC, Monte SS, Jeep GC, etc) steering boxes in older GM cars actually fits?
71RS/SS396
05-30-2013, 04:33 AM
I'm almost positive nobody makes a replacement for 79-81 cars, you will either have to do like Carl did and frankenstein it, replace the column and intermediate shaft to the earlier style, or use borgeson u-joints and double D shaft.
badazz81z28
05-30-2013, 05:24 AM
Stay away from this guy.
Skip Fix
06-12-2013, 02:34 PM
I had a Dorman HELP reapir kit on the 81 TA. It is basically just the rubber and it bolts up the the shaft and to the spline portion. I think 78 was the last year for the ones that are still available. My 79 Camaro I used Borgeson collpasible double D shaft and U joints. It is about 0.010 too loose on the column end but made a shim from a feeler gauge.
I saw on one site a guy was starting to repoping the entire internediate shaft(which has the rag joint riveted to it stock) them from Australia either nastyZ28.com or transamcountry.com forgot which.
Skip Fix
06-12-2013, 07:23 PM
http://transamcountry.com/community/index.php?topic=40126.0
Here you go.
