View Full Version : Where to find scales to weight my car?
b17brian
05-23-2013, 09:10 AM
I live in a small town and don't know what type of business I would go to around here to get my car weighed using four corner scales. We don't even have a speed shop here and the drag strip closed last year. What type of business do I look for that would have four scales to weigh my car?
andrewb70
05-23-2013, 09:36 AM
Any decent shop that caters to circle track racers will have scales and a flat plate set-up.
High Plains Mopars
05-23-2013, 11:11 AM
May nto have four corners scale, but Drywall companies, landscaping companies, grain elevators. Like Andrew said, oval track builders, street rod shops, other chassis fabricators.
Depends on where you're at. Florida is a big place.
rchaskin
05-23-2013, 11:17 AM
Dont forget about the landfill, or the scrap yard!!
b17brian
05-23-2013, 09:18 PM
Thanks for the replies. But I’m not looking for total weight. I’ve been reading some books about suspensions and they recommend 50/50 front to back weight ratio. So I wanted to know where my Camaro stood as far as weight balance. I live in the Florida panhandle, I guess I’ll see if there are any circle track shops in Pensacola. Thanks guys.
TLWiltman
05-23-2013, 11:46 PM
Another thing to try if that doesn't work out. The local landfill (or any of the above) may have a scale. Drive the front tires on, note the weight. Drive forward until the front tires are off the scale pad, Note the weight. It's not perfect, but very close. I'd guess 55F/45R to start, but may be a bit more front heavy than that to start with if you're stock.
UMI Tech
05-24-2013, 04:35 AM
If you have any local speedways (i.e. dirt or paved ovals), call their office and ask if they know of a friendly racer who may let you swing by their shop and use their scales. Like Andrew mentioned, oval track guys weigh all four corners and most are cool enough to help others in the car hobby.
ramey
Josh@Ridetech
05-28-2013, 05:14 AM
If you're near any NSRA or GoodGuys events, come to the Ridetech booth. We normally have our scales out and ready to go!
