Redlines
05-22-2013, 05:28 AM
7650576504
Rotating assembly (rods, pistons, rings only since the crank has been sold) from a LSX 440 engine build using a GMPP LSX 454 block. Was balanced, assembled and installed however decided to sell car and part out the build. Removed from engine, zero miles on it. 4.185 pistons with 6.125 rods
Wiseco Forged LSX 10-K463X185 Piston set 4.185 bore, -2,8cc flat top, GFX 1.2/1.2/3.0mm steel top rings, napier 2nd ring pack. Designed to accommodate the reluctor ring on stroker cranks without having to notch the pin bosses. Strutted skirt design is the strongest and specially designed to run at as little as .004" clearance, with excellent skirt wear and minimal noise or rock. Radiused Valve Pocket for detonation resistance and increased flow around valves. Anti-detonation Grooves with the added benefit of keeping the top ring groove free of carbon. 3mm oil rings for better oil control and reduced friction for more horsepower. Pressure Groove for enhanced ring seal. Features Chrome Moly Pins and Spiralox. Race-ready domes don't require deburring by the engine builder. Skirt coated for lower friction, reduced noise, and superior life. Multi-fit valve pockets for interchangeability of cylinder heads
Scat's LS1 6.125" Forged H-beam Connecting Rods
Will include the rod bearings too that TX Speed included in this rotating assembly.
4340 FORGED H-BEAM RODS with ARP 2000 7/16" Cap Screws The “Bad Boy” of all SCAT Rods available for serious horsepower engines. H-Beam design is the strongest SCAT rod available. Perfect for supercharged and nitrous applications Special doweled cap for specific cap-to-rod alignment
Profiled clearance for stroker applications
$1100 obo, buyer pays shipping, paypal accepted with their 3% added to shipped total
