View Full Version : Not PT/ Looking for someone to build LQ9 harness for rock buggy.
k9kevin81
05-16-2013, 02:37 AM
I know its not PT related but I know this is the place to ask LS related questions. As stated in the title Im looking for someone to modify an org. LQ9 harness for a rock buggy. Do you think it would be cheaper/better to get a new harness? What currently running and need to work:
LQ9
DBW
LS6 Intake/TB/Rails
TH350 tranny
Just needs Headlights, brake lights, running lights, and a bunch of 12v accessories. NO A/C.
Any suggestions on a good low RPM high torque cam would be awesome as well.
Kevin
sniper
05-16-2013, 06:24 PM
LQ9
DBW
LS6 Intake/TB/Rails
TH350 tranny
It's probably not what you want to hear, but those harness's are practically stand alone already. There is not much that needs to be done to get it working. DBW has it's own tac module so make sure it matches the pedal otherwise, no bueno.
You can get the harness info all over the net. Then take out what you don't want or need and that will cut the clutter way down. Constant and switched power, some fuses and relays, couple of grounds, whammo. Your own harness.
Jetfixr320
05-16-2013, 08:33 PM
Try this place out.
http://www.lt1swap.com/2000harness.htm
Or this,
http://www.lt1swap.com/gen3_schematics.htm
