SSLance
05-15-2013, 11:50 AM
I'm looking for a way to gain some rear suspension travel to keep my frame off of the bumpstops during hard corners while autocrossing.
I'm running DSE 2" drop springs, and the 1 5/8" PU bumpstop that came with them on my QP 9" with the Ford racing disc brake kit with the calipers clocked low and to the front. The top caliper mounting bolt is the first point of interference if the suspension cycles too far followed very closely by the bump stop mount itself.
Here is the suspension compressed (springs and shocks removed) until the current bumpstop was up against the frame
https://static1.pt-content.com/images/pt/2013/05/DSC02121-1.jpg (http://smg.photobucket.com/user/LSVLance/media/1985%20Monte%20Carlo%20SS/DSC02121.jpg.html)
Here is pretty much the same shot with the bump stop removed
https://static1.pt-content.com/images/pt/2013/04/20120829_185328_443-1.jpg (http://smg.photobucket.com/user/LSVLance/media/1985%20Monte%20Carlo%20SS/2012-08-29_18-53-28_443.jpg.html)
This is at ride height, shows at or around 2 1/4-2 1/2" of travel with current bump stops
https://static1.pt-content.com/images/pt/2013/05/DSC02146-1.jpg (http://smg.photobucket.com/user/LSVLance/media/1985%20Monte%20Carlo%20SS/DSC02146.jpg.html)
I have a set of OEM rubber bump stops in the 2 5/8" height and today I ordered a used set of OEM rubber bump stops in the 1 5/8" height.
My thought is to trim a set of them down to 1/2-3/4" height or so just to give protection to the caliper bolt from bottoming against the frame while increasing my suspension travel at the same time. Haven't decided which set of stops to try trimming on first though?
Am I looking at this correctly? Is there a better way for me to increase my suspension travel without raising the car back up? Would I be better trimming on the PU stops or the OEM rubber stops? What do I have to be careful about in that regard? Should I trim them to a point like the OEM ones or just cut the top of them off flat?
Appreciate any help anyone can give.
Lance
Lance
