View Full Version : Caliper hose length C5/LS1 brakes?
Vicinity
05-15-2013, 09:35 AM
I need to change out some hoses on my setup, and I was wondering if anyone knew the proper length of the C5/LS1 style brake caliper hoses (between caliper and hard line), I'm about to order a 3 piece set from Kore 3 and they require a length. Also, if you know the fitting sizes for each end, it would help, otherwise, I'll go and dig through all my info and find it.
Rhino
05-15-2013, 10:55 AM
Both C5 and the 4th Gen F-body brakes will use 10mm banjo bolts at the calipers. Stock your first gen would have 3/8-24 female inverted flares on the chassis side.
C5 hoses are 16.5". If I recall correctly I remember Tobin posting something about they would typically supply 14" hoses in this configuration.
Vicinity
05-15-2013, 11:48 AM
I made it work with whatever stock size bubble flare GM used on the ends of the LS brakes, I think it was a 12mm bubbleflare on the opposite end of the banjo, I can't recall exactly. I was thinking about getting 12in hoses, but if Tobin recommends 14", I'll go with that.
Rhino
05-15-2013, 03:43 PM
If you're looking at the chassis end of the stock C5 hoses they'll be M10x1 bubble flare. C5 masters am have one of the fittings that's 12mm
Vicinity
05-15-2013, 03:46 PM
Ah, yes, you are correct. Thanks!
brownz
05-15-2013, 05:54 PM
hmm I never said a length when I got my lines... just said c5/ls1 rear
Vicinity
05-15-2013, 06:11 PM
Wow, I just realized they sell pre-configured sets for C5.
brownz
05-15-2013, 06:14 PM
Dan
Have you called tobin yet? Im sure he can help. I have always got great info from a phone call. He sold me a pre-configured set for my nova c5 front and ls1 rear.
