Firebird-Geek
05-14-2013, 08:38 AM
INFO:
67 Firebird
I know many say to rebuild the hinges you have because the aftermarket are not very good. But my hinges were in VERY bad shape and possibly bent.SO I am kind of forced to use aftermarket hinges.
Question: Is there a certain part, area or item I should be concerned about? Is there a way to rebuild the aftermarket hinge to make it as good as a GM? What should I get... parts? :help!:
I would rather rebuild the hinges now, than later when the car is put together and I have to deal with paint and fitment.
Here is what I have:
*Lower Hinges is suppose to be a "GM Restoration Part" and does look like it is a rebuild factory hinge. Are these OK? area of concern?
https://static1.pt-content.com/images/pt/2013/05/IMG_066825202528Large2529JPG-1.jpg
https://static1.pt-content.com/images/pt/2013/05/IMG_066925202528Large2529JPG-1.jpg
https://static1.pt-content.com/images/pt/2013/05/IMG_067025202528Large2529JPG-1.jpg
*Upper Hinges are reproduction: I do see they use some sort of plastic bushing rather than a brass bushing like the factory hinge. Should I replace these right away with brass? or is plastic just as good?
https://static1.pt-content.com/images/pt/2013/05/IMG_067125202528Large2529JPG-1.jpg
https://static1.pt-content.com/images/pt/2013/05/IMG_067225202528Large2529JPG-1.jpg
67 Firebird
