BMR Tech
05-13-2013, 07:40 AM
BMR Suspension
Pro-Touring Upper A-arms for 64-72 GM A-Body Vehicles
<o:p></o:p><o:p></o:p>
Improve handling and front end stability in your 1964-1972 A-Body with a set of Pro Touring upper A-arms from BMR Suspension. Manufactured from 1.25” DOM tubing and laser cut 3/16” mounting plates, these arms feature low-deflection, internally-fluted Delrin bushings with easy-to-access grease fittings. The BMR Pro Touring Upper A-arms (AA028) feature taller ball joints for an improved camber curve, 2 additional degrees of positive caster for increased high speed stability and increased camber gain while turning, and shorter A-arm tube lengths for a smaller shim stack on lowered vehicles. This A-arm will outperform the OE arms in every aspect – less weight, better performance, and increased strength. Available in red and black hammertone powdercoat finishes. Installation time of 2-3 hours.
<o:p></o:p>
<o:p></o:p>
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com (http://www.bmrsuspension.com/), email [email protected] ([email protected]), or contact them at BMR Suspension, <st1:Street w:st="on"><st1:address w:st="on">12581 US Highway</st1:address></st1:Street> 301 North, <st1:place w:st="on"><st1:City w:st="on">Thonotosassa</st1:City>, <st1:State w:st="on">FL</st1:State><st1:PostalCode w:st="on">33592</st1:PostalCode></st1:place>, 813-986-9302, Fax: 813-986-8055.
75997
<o:p></o:p>
<o:p></o:p>
75997
