View Full Version : motor 75 350
hag6888
05-10-2013, 11:20 PM
I'm mounting 75 350 I'n a 67 Chevy C10 brackets are diffrent for the motor mounts have a bolt that goes threw the bottom on the 75 350. What motor mounts should I get ?
andrewb70
05-11-2013, 09:47 AM
The 67 Chevy mounts are probably the same as all pre-1973 style mount. I just looked up motor mounts on Rockauto for a C-10, and surprisingly, none are listed. Can you post some pictures of the front cross member and the mounts that you have on the engine?
cornfedbill
05-11-2013, 03:59 PM
All the Chevy small blocks had the same three mounting bolts on the sides of the block from '59 to '99. Most of them, except some lightweight mid-70's blocks also had the holes in the front for the '55 to '58 front mounts. I bolted a '99 small block in my '55 Belair using the stock mounts and the holes already in the block.
I guess I would also need a picture to see what is not working for you. There is something I do not know here.
hag6888
05-12-2013, 12:29 AM
There is my motor that 75 350 ill take a pic of the mounts that were in the truck
andrewb70
05-12-2013, 04:38 AM
That's the later clam shell style mount. You just need to get the early style mounts. With a picture of your cross member we can co firm for sure. Energy Suspension makes nice poly ones, you'll just have to figure out if you need the short and wide or tall and narrow style. The mounts on the frame should answer that question. Most auto parts stores will have what you need in stock.
hag6888
05-12-2013, 03:59 PM
Old style motor mounts
andrewb70
05-12-2013, 06:01 PM
Looks like the "tall and narrow" mounts will work for you.
http://energysuspension.com/products/Motor-Mounts.html
