View Full Version : Rear lights out! NEED ADVICE
mmag36
05-08-2013, 04:32 PM
Hey guys, my rear lights are out on my 67 GTO with a newly installed American Auto Wire kit. Everything was working for a few days but now the rear lights do not work when I turn on my headlights. The brake lights DO work! Clearly I am a electrical novice and do not pretend to understand everything regarding the electrical system. I am looking for some trouble shooting advice. All fuses are intact and bulbs are good....now what?
Thanks in advance!
Mike
BuzzKillian
05-09-2013, 02:26 PM
Make sure your grounds are good. Use a Volt meter to see if you have voltage to the Socket. I am assuming you did a complete harness? Go back to your connectors and make sure a spade didn't push out when you pushed them together. If that doesn't work, call AAW tech support, they stand behind their product.
MuscleRodz
05-09-2013, 09:05 PM
You have a bad ground. Check the grounds for your taillights. make sure they are to bare metal.
