View Full Version : 72 Ventura LT1, T56, 3.73, GTO seats, fresh complete resto
vaventura
05-06-2013, 07:22 AM
Turn key ready for shows and cruising completely rebuilt frame off build. This car has just 70 miles since build completed. Might consider partial trades for shortbed 2wd Chevy/GMC pickups.
Just completed: 2 year resto. 1972 Pontiac Ventura II . This car is a 2 owner Virginia car with less than 70 miles since build completed. Fresh, complete frame off restoration starting with a 2 owner VA car. Car is located 30 minute east of Richmond. Call me for more details seven five seven.775.5316.
Drivetrain:
Engine: 1995 5.7L LT1
-Completely rebuilt with new moly rings, bearings, lifters, oil pump, timing chain, seals
-New temp sensors, knock, tps, iat, pcv, coil
-New optispark, waterpump
-Rebuilt starter, alternator, power steering pump
-pcm tuned to remove airpump, egr, set gear ratios, fan temp, etc.
-Hedman headers.
Cooling:
-New dual core 95-2002 Camaro radiator
-95 Camaro Factory dual electric fans controlled by the PCM
Transmission: 1995 T-56 6 speed manual
-Trans disassembled and inspected, new seals
-New flywheel, clutch, pressure plate, throwout, master and slave cylinders
Rear: 10 bolt limited slip
-Disassembled, cleaned
-New Richmond 3.73 gears
-New Auburn posi
-New Summit Racing alloy axles, seals, bearings, install kit
Chassis:
Features:
-Frame and components stripped down and media blasted. Chassis was rust free with no pitting.
-Painted with single stage urethane satin black.
-Complete new rebuild with new ball joints, tierod ends
-Complete Energy Suspension bushing kit front and rear.
-Energy Suspension body mounts.
-Hotchkis Springs, Hellwig sway bars front and rear, KYB gas-adjust shocks.
-All parts painted or gold zinc plated.
Brakes:
Features:
-Completely new 11" front and rear disk brakes with slotted rotors and new calipers.
-New booster, master and proportioning valve.
-All new lines, hoses, fittings, clips, hardware.
Wheels/Tires:
-Chrome Ridler 695 wheels 17x7 and 18x8
-Cooper ZEON RS3-S 235-45-17 and 245-45-18
Exhaust:
Features:
-Complete stainless steel 2.5" Magnaflow exhaust exiting in the factory location.
Fuel system:
Features:
-New Spectra Premium fuel tank with high flow in tank baffled electric fuel pump.
-All new fuel, return and vent lines with double flare or gm push connect fittings
-Factory style vent and charcoal canister.
Body:
Vehicle had rust free floors, trunk. The body was stripped down to bare metal with minimal bodywork required. Painted Jet Black BC/CC
Features:
-69 Camaro front and rear bumpers front valence, spoiler.
-Custom rear valence.
-Nova taillight panel with center mounted Stainless Steel fuel filler.
-73 Sprint grill header (dura-glass) with custom made grill inserts.
-Underside stripped of all undercoat and painted with single stage urethane satin black.
-Filled firewall with hidden heater and A/C lines.
-Trunk painted with factory style gray spatter paint.
Glass:
-Near flawless factory tinted glass.
Trim/lights:
-New door handles, locks, ignition.
-New complete taillights, marker lights, headlights with directional and driving lights.
Interior:
Features:
-2004 GTO Black Leather seats.
-New Door panels, carpet, headliner, sound/thermal barrier.
-Custom fabricated dash insert with Summit Racing digital gauge panel (includes speed, tach, odometer, water temp, oil pressure, fuel level, high beam, directional, max speed, 0-60 and 1/4 mile functions).
-Vintage Air A/C system.
-Sony MP3 CD stereo.
-Custom billet dash knobs.
-Forever Sharp billet half-wrap steering wheel.
-Rebuilt manual steering column with new ignition and directional components.
-All new weatherstripping.
Slideshow link: http://s1022.photobucket.com/user/mrouette/slideshow/72%20Ventura%20Restomod
https://static1.pt-content.com/images/pt/2013/04/DSCN2437-1.jpg
https://static1.pt-content.com/images/pt/2013/04/DSCN2407-1.jpg
https://static1.pt-content.com/images/pt/2013/04/DSCN2390-1.jpg
https://static1.pt-content.com/images/pt/2013/04/DSCN2395-1.jpg
https://static1.pt-content.com/images/pt/2013/04/DSCN2400-1.jpg
GS163
05-07-2013, 12:01 PM
Ill trade you a '96 red interior Grand Sport. :)
vaventura
05-14-2013, 10:56 AM
Ready for spring!!
vaventura
05-20-2013, 10:59 AM
bump
vaventura
05-27-2013, 07:30 AM
vaventura
06-04-2013, 07:04 AM
still available
vaventura
06-06-2013, 05:34 AM
Everyone has a Camaro, here's you chance to be different.
vaventura
06-18-2013, 04:03 AM
bump
vaventura
06-26-2013, 06:33 PM
bump
GS163
06-29-2013, 05:39 AM
I'm still interested. :)
vaventura
07-08-2013, 03:35 AM
Still available....ready to show.
vaventura
07-22-2013, 12:43 PM
sold
