View Full Version : 12.19 inch rotors for wilwood calipers on A-body?
Nothingface5384
05-01-2013, 11:07 PM
I'm just wondering if theirs anyway to use the wilwood d-52 and d154 calipers to max..right now im rolling with the 11inch rotors.
calipers accept up to a 12.19 rotor but I have no idea what would work on my 72 skylark and will they take stock bearing/races?
Thanks in advance
Nothingface5384
05-06-2013, 08:46 PM
well, i'll just answer my own question...kore 3 billet hub with slip on rotor
Apogee
05-07-2013, 07:14 AM
Not so fast...whats' your goal switching to a larger diameter rotor? While you will increase the overall brake torque due to the longer moment arm, your 11" OE rotor is 1" thick whereas the Wilwood 12.19" rotors are only .81" thick for the most part, so you may actually be decreasing your thermal capacity. What's the bigger picture here?
Tobin
KORE3
Nothingface5384
05-07-2013, 08:26 PM
yeah, just realized the 12x1 said REAR :-(
I can still upgrade to 11.75 x 1.25 rotors
may try the ls1 rotors from advance to see if that, d52 dual piston calipers and a 15in rim clears once i get the kore billet hubs which reduces track width a tad
btw,
Just trying tp max out my braking while retaining my 15in rims
Skip Fix
05-08-2013, 07:13 AM
Using a 12 " rotor B body spindle and 1LE rotor will get pretty close to and actual 12" rotor and uses a D52 caliper and fits most 15s. Find some station wagon or police car spindles. Taller spindle will need more shims or a new upper control arm for an A body.
Nothingface5384
05-08-2013, 09:25 AM
yeah..I dont want to use a b-body spindles due to drop with no geometry gain, not worth the effort for little rotor gain
..if im ever going to switch spindles it'll be for a l&H kustoms or afx piece which are the only two spindles worth the swap
jake72ss
05-08-2013, 10:01 AM
US Brake makes a 12.19 x1.25 rotor you could use with the wider wilwood D52 Caliper, the correct rotor hat is the missing link
Nothingface5384
05-08-2013, 10:31 AM
do you have a link?
jake72ss
05-08-2013, 04:56 PM
http://www.speedwaymotors.com/US-Brake-Straight-Vane-Rotor-1219-x-125-Inch,40505.html
http://www.speedwaymotors.com/AFCO-6640103-Pillar-Vane-Flat-Rotor-125-Inch-1219-Inch-Diameter,66947.html
http://www.speedwaymotors.com/AFCO-6640110-1219-Inch-Pillar-Vane-Slotted-Rotor-125-Inch-RH-Side,66961.html
Hope this helps
Apogee
05-10-2013, 08:26 AM
What's the budget? You could go with something like the vintage race guys run, C3-based kits with an 11.75" x 1.25" rotor and 4-piston caliper. The OE calipers can be a bit tempermental and heavy, but Wilwood makes an aluminum D8-4 and D8-6 replacement option at a fraction of the weight and conventional square o-ring piston seal designs which really don't cost much more than the OE units and you can even upgrade to Thermlock pistons if you want.
Tobin
KORE3
