View Full Version : CPP C5 Spindle Brake Kit - Who Has Used Them?
Glock 18
05-01-2013, 05:49 AM
Has anybody actually used the new CPP C5 Spindle Brake Kit on the street, road course, autocross, etc? I want to do my research on these before pulling the trigger. I need complete front brake setup for my Chevelle. Thanks Guys!
novajess1972
05-01-2013, 07:56 AM
I was initially skeptical in purchasing them for my 72 Chevelle, but I reluctantly pulled the trigger.
I am proud to report that they install, fit, and perform flawlessly! I have had them on for about 3-4 months now (since they were introduced) and am quite pleased with them. Very hard to beat, considering the price of your Baers, Wilwoods, SSBC's, and the like. Yes, I'm sure those brands offers some better quality parts here and there, but I am just as concerned with quality performance...and these deliver!
No autocrossing, but I am a very spirited (read: AGGRESSIVE) driver. I am running QA1 adjustables on all 4 corners, SPC upper/lower controls arms, Hotchkis sway bars front and rear, along with their rear lower control arms. I give anyone that even looks at me the wrong way the business on the highway...and the CPP C5 kit hauls my big girl down from speed effortlessly!
The only thing I would recommend is swapping the pads for ceramics. Not sure the reasoning, but CPP loads the calipers with a semi-metallic pad to maybe cut costs...not sure...but they are noisy after getting some heat into them, and they give off quite a bit of brake dust. I simply switched to ceramic AC Delco pads...problem solved. And they were only $39 on eBay.
I recommend highly...and no, I have no vested interest with CPP. Just a satisfied customer.
Hope this helps.
Glock 18
05-01-2013, 09:56 AM
Yes! Thanks for the quick reply. So your Chevelle isn't a purpose-built track car? ... mine either. But would you drive it hard on an autocross track or road course? Second, did you realize any handling differences with this kit? Thanks again!
Anybody else? Please tell me, The good, the bad, the ugly. Your input will definitely be appreciated!
novajess1972
05-01-2013, 10:31 AM
No...not a purpose-built track car. I purchased it as a recreational/leisurely cruiser, as I assumed the deeper I got into better handling/braking performance, the further I would go into the poor house. I initially did some just-to-get-by type upgrades...cheap dropped spindles, cheap disc brake upgrade (with old school GM spindle), coupled with better quality pieces such as Hotchkis springs and Bilstein shocks. That's where I thought it would end, as I was also trying to build up the motor and tranny at the same time, as it came with a tired 350/350 combo. As long as my stance was right, I felt I was good to go.....how wrong I was.
After some rough riding, poor handling, and premature tire wear, I decided to get serious about my suspension and the parts I chose. It was one of those things that kind of snowballed. I never intended to drop as much cash on suspension as I did. Now I am a firm believer in the 'suspension is one of the best/most effective upgrades you can make to your car' philosophy that so many follow.
I know I ramble, but to answer your question - yes, I did notice improved handling. However, I can't necessarily credit that entirely to the CPP kit, as I did the SPC uppers/lowers and close ratio steering box at the same time that I installed the CPP kit. But again, I know for sure that the braking is much improved over the basic drum-to-disc conversion that I had installed. I spent a crap ton of money by trying the cheaper alternatives to save a buck.
And no, I would have no qualms putting it on a road course. I recognize it's a different animal that spirited highway driving, but I feel she would hold her own out there.
Glock 18
05-01-2013, 05:32 PM
That sounds great for the CPP parts. Thanks for your time and your help! As a side note, I read on another site that Summit Racing sells the CPP kit cheaper than CPP sells it for. One guy had the kit delivered for $590 I think!
Who else uses the CPP C5 Spindle Brake Kit? Please jump on in here if you do.
V8240Z
05-02-2013, 04:35 AM
I have them on my 73 Camaro and am very pleased. I never really drove the car with the old brakes because of poor braking. The parts fit well, look good, and most importantly the car stops! I do plan on changing out the pads asap and getting some Hawk pads.
Glock 18
05-02-2013, 04:55 AM
Thank you for the input. I actually thought the Hawk pads would be a nice upgrade too. Still wanting a few more to share their thoughts on these...
novajess1972
05-02-2013, 05:07 AM
I also was going to go with the Hawks, but I decided to get some feedback from actual C5 drivers on a Corvette forum. Several recommended the AC Delcos for the peformance...and the price point. Hell, I figured...at only $39, I can afford to try them, then upgrade to Hawks/EBC/Carbotech if the ACD's turned out to be crap.
Glock 18
05-02-2013, 07:32 AM
That is a good point. Thanks.
Glock 18
05-02-2013, 02:41 PM
Hey Guys does anybody else have the CPP C5 Spindle Brake Kit in your car? Looking for feedback, good or bad. Thanks.
67machrod
05-02-2013, 05:56 PM
I just installed a set on a 67 Chevelle. Fits well have not had a chance to test them out yet. Also fits American racing cl205 17" wheels!
Glock 18
05-03-2013, 06:01 AM
Thanks for the reply. Can you post your opinion on these after you test them out?
chevelletiger
05-03-2013, 07:22 AM
could you get me a part# on the pads you got on ebay?i have the vette c5 calipers on all four corners but need pads.thank you.phil
novajess1972
05-03-2013, 05:12 PM
I can't locate part number, but if you PM me your email address, I can forward the eBay listing. I thought it might be on the listing, but I don't see it.
JW
splatt
05-06-2013, 09:32 AM
I thought TTII won't clear c5 calipers without spacers. Are the CPP calipers different?
GTTO
06-21-2013, 06:02 AM
I also just threw their Front C5 set up on my 68 GTO this spring. They do fit... after awhile. The parts of their machined brackets didnt fit each other (The disc spindle spacer they give you). I sent an email to them and heard nothing back. I was happy with other purchases from them, but now i feel like the quality wasnt there on this one. This was my list i sent them.. and heard nothing:
This kit is not bolt on... and does require some machining. I am not happy with the quality of this kit so far.
-Aluminum bracket, the tolerances are not the same between the two i received. Both required some drilling of the mounting holes just to fit the bolt to the spindle. Second issue is the fitment to the caliper...the caliper was hitting a portion of the machined relief.. which needed to be take down so the caliper would sit flush on the bracket for a proper mating surface.
-Bolt package that came with the kit? WTF are those for? They dont fit the caliper and they dont even fit in the holes if you were going to use one for the bracket to the spindle. comes with washers, lock washers, nuts, and two length bolts that were ENGLISH Thread.
-No caliper bolts were included. M14x2.0 x 35mm You need 4 of them.
-wheel studs included, nice thought, they are completely different diameter spline neck.
-Calipers are not C5 calipers!!
Sorry not a super negative guy, and glad some of you had no issues with them!
DButler
06-24-2013, 09:39 AM
Are you referring to c5 or c4/c5 hybrid kit? I am running the hybrid kit and it is good so far. The studs where wrong but everything else worked out good. I used the stock drum spindles with my kit. The spacer mentioned above is if you use stock disc spindle. For the money I can't complain...they stop much better than stock...I will be upgrading pads though
wadem
06-24-2013, 05:58 PM
Post some pics of the kits installed and which wheels you guys are running,I'd love to see what you guys are using
79-TA
06-25-2013, 05:48 PM
GTTO, what exactly did you order? CPP C5 kits use a brand new steering knuckle (aka spindle or upright) and the normal big brake kits use steel brackets, not aluminum. Do you have any pictures?
Ron Sutton
06-25-2013, 06:28 PM
Can you guys post some photos of them installed?
:postpics:
V8240Z
06-25-2013, 08:28 PM
https://static1.pt-content.com/images/pt/2013/06/4CB431498EBA47159E2E1144CA64DBB715302000-1.jpg (http://s1325.photobucket.com/user/charles_davis3/media/4CB43149-8EBA-4715-9E2E-1144CA64DBB7-15302-00002A621659DABF_zpsc7559ca8.jpg.html)
This is on my 73 Camaro.
https://static1.pt-content.com/images/pt/2012/12/B678247F4DEF4343A200105565B43F8788700000-1.jpg (http://s1325.photobucket.com/user/charles_davis3/media/B678247F-4DEF-4343-A200-105565B43F87-8870-000016F10B5E08DF_zpsdd37c58a.jpg.html)
Behind 18" Rocket hyper silver Booster wheels
car_guy
09-25-2013, 07:52 AM
I just installed these on my rolling chassis for my 70 LeMans. Very pleased with the fit and quality so far. They arrived fully assembled and ready to go. I took them down just to compare etc and check fit. Here are some pics.
https://static1.pt-content.com/images/pt/2013/09/IMG2013092300273_zps3c4e3728-1.jpg (http://s725.photobucket.com/user/carguy_1/media/IMG-20130923-00273_zps3c4e3728.jpg.html)
https://static1.pt-content.com/images/pt/2013/09/IMG2013092300319_zps6ba88f02-1.jpg (http://s725.photobucket.com/user/carguy_1/media/IMG-20130923-00319_zps6ba88f02.jpg.html)
https://static1.pt-content.com/images/pt/2013/09/IMG2013092300328_zps46842b23-1.jpg (http://s725.photobucket.com/user/carguy_1/media/IMG-20130923-00328_zps46842b23.jpg.html)
https://static1.pt-content.com/images/pt/2013/09/IMG2013092300331_zpsda852a69-1.jpg (http://s725.photobucket.com/user/carguy_1/media/IMG-20130923-00331_zpsda852a69.jpg.html)
https://static1.pt-content.com/images/pt/2013/09/IMG2013092300274_zpsa9e0d3a1-1.jpg (http://s725.photobucket.com/user/carguy_1/media/IMG-20130923-00274_zpsa9e0d3a1.jpg.html)
https://static1.pt-content.com/images/pt/2013/09/IMG2013092300340_zps0327fa66-1.jpg (http://s725.photobucket.com/user/carguy_1/media/IMG-20130923-00340_zps0327fa66.jpg.html)
behind 17x8 Billet specialties split spoke...using 1/4" spacer for clearance...Just realized i put the wrong side rotor on for the pics, haha.
novajess1972
09-25-2013, 09:04 AM
Updated review of the CPP C5 spindle/brake kit:
Although I upgraded to a Wilwood 6 piston setup on my Chevelle, the CPP C5 continued to perform and impress the entire time I had them (about 9 months). They never skipped a step and stopped on a dime, even during more than spirited driving.
One and only gripe or suggestion to newer buyers and those that have yet to install - try using some sort of clear coat or rust inhibitor on the spindles. They come a nice gray out of the package. However, after some time under the car, they turned a rust color. Can't confirm if it is actual rust, but it appears the same. Affected performance in no way. It just wasn't attractive. Not sure if it was caused by them getting wet when I washed my car (as disc brake rotors often do) or just a reaction to the elements overall.
Again, if you don't have other pretty components under then, this may be of little or no concern to some. But I upgraded everything under mine (SPC UCA/LCA, QA1 Coilovers, Hotchkis sway bars, and Billet Specialties wheels) so, naturally, I want something that at least appears as quality to go compliment those parts.
So Car_guy - while you have them off, figure out something to cost them with or paint/powdercoat them to prevent them from turning ugly. I see that you have some nice, clean parts and aftermarket wheels.
Hope this helps.
JW
novajess1972
09-25-2013, 09:27 AM
:postpics:
Just for you, Ron
CPP Kit with old wheels, new wheels, and new Wilwood 6 piston setup. Pics are kind of out of order.
sanman
09-28-2013, 08:35 PM
Hi all, Check out Camaro Performers online and look through their tech section. I don't recall the month, anyhow look for the red CPP caliper that's my ride attached to it. Was a great experience and I have to say they work very good. I agree about upgrading the pads, other than that they work great. We put the Pro Touring 4 kit on.
camaro427-69
10-06-2013, 11:19 PM
i just installed a set but it was more of a p.i.t.a. at first my setup is a steeroids rack and iīm running z51 C6 brakes and forgeline 17"wheels. i havenīt had the ridtetech upper arms in the beginning due to budget, just a set of those cheap arms with proforged tall ball joints, and there was no way to turn the wheels without hitting the wheel on the upper arm. so i had to either change the ball joints but still have to cut the arms to make more space but i went with the ridetechs. now it fitīs way better but still have to grind some material off the metal from the upper arms to get all steering i have. the rack even has less turning radius than the stock box and i donīt want to loose any more of it so iīd rather grind. the steering arms is another issue cause i used my stock arms and they almost hit the wheel on the bottom so i got a set of the arms ridetech use on their tru-turn kit cause they are not bent downwards just straight back and use the spacers to adjust the bumpsteer but there was no way to mount the calipers cause they would have hit. so for me itīs got nothing to do with a clean and easy setup but it surely would be different with the whole kit and not just the arms and different parts.
8339983400
Blue66
11-23-2019, 06:17 PM
Any update on these spindles guys? I have a pair of brand new oem c7 hubs, c6 calipers, pads and rotors ready for my vette brake upgrade.
I cant decide if i want to trust an affordable china cast or drop a mint on the speedtech units from sc&c
Blue66
11-23-2019, 06:55 PM
For the life of me I can't find one example of a CPP spindle failure. There sure is a lot of people talking about how weak they are and everything by there being no examples. I don't like opinions I like reading about facts and real experiences
79T/Aman
11-24-2019, 09:28 AM
Here is the problem, there are too many online that combine everything they read into a stew of baseless facts, the problem is the cheap offshore hubs in the kit, they fail, not the spindle, the knock off calipers have had issues as well, so get the spindles and then buy good SKF or C7 hubs and real PBR calipers.
timopajala
11-27-2019, 01:51 AM
I have The c5 kit on My 1967 Camaro and they work really good. No problems on The installing etc. Have been driven about 3000mails with them so far. Only The bearings feel quite stiff to rotate but i let you know how Kong they last.
130fe
11-27-2019, 05:13 AM
Does the CPP kit reposition the caliper back towards the hat? I know the the "normal" C5 setups (like Kore3) limits the usage with some of the cheaper wheels like TT2 and such because of caliper/wheel interference. I think if you upgraded the hub most drivers (cruisers mainly) would be good with this choice.
timopajala
11-27-2019, 06:24 AM
Does the CPP kit reposition the caliper back towards the hat? I know the the "normal" C5 setups (like Kore3) limits the usage with some of the cheaper wheels like TT2 and such because of caliper/wheel interference. I think if you upgraded the hub most drivers (cruisers mainly) would be good with this choice.I have The whole kit with The new style pressed bearings like Corvette has. Really nice setup and easy to Bolt on.
