Barrrf
05-01-2013, 05:46 AM
Ok, I read through the directions, sorted out all the parts, then went to attempt the installation which by all means a monkey should be able to do.
But the directions dont match what I think should happen.
http://static.summitracing.com/globa.../ens-17022.pdf (http://static.summitracing.com/global/images/instructions/ens-17022.pdf)
Starting with the pictures in the instructions that show the stack - it appears as if the bushings should fit inside each other. Well they dont. Not even close really.
Question pertaining to position #2 - shows, again, the boss on the bottom bushing going up through the "bracket" (which is the bracket welded to the firewall with the access hole) but I can assure you the hole going up through this bracket is only slightly larger than the bolt that sammishes the whole thing to together. So its my thought that the bushings should go boss down through the much larger hole in the frame to help keep the bushings located and have the larger flat surface of the bushing against the body. Is that right?
Also, I found a couple threads pertaining to Energy Suspension installation but the pictures had been removed. Any help on this will be much appreciated.
