View Full Version : Wtb 67-69 camaro front STOCK subframe. Located in Texas
stealthjr
04-25-2013, 06:44 PM
Tell me what you,have please...thanks!
Robert
CHUCKIE
04-27-2013, 10:05 AM
Hi,
I don't have a frame but I do have most suspension parts. Upper control arms, lower control arms both with newer ball joints and urethane bushings.Have tie rods, center drag link, idler arm, New short shaft manual steering box.
I decided I’m sticking with the stock subframe. Thanks, Corey
DEIGuy38
04-28-2013, 06:58 PM
I have these parts for sale for a subframe but do not have the subframe
https://www.pro-touring.com/showthread.php?95137-67-69-Camaro-Firebird-amp-68-74-Nova-Suspension&highlight=
stealthjr
04-29-2013, 07:30 AM
Hi,
Chuckie,
I might be interested in the center drag link and idler arm...let me know how much please shipped to 75028.
Robert
stealthjr
04-29-2013, 07:33 AM
Robert, I have a 69 subframe complete with manual quick ratio steering box and disk brakes. It doesn’t look to be wreaked or have any issues. I’m not exactly sure if I’m sold on selling it yet but may up going the speed tech route so give me a call. That’s if AZ isn’t too far away.
Corey 714-658-6291
Hi Corey,
Is this an OEM subframe or the Art Morrison mentioned in your signature? Also, sounds like you are wanting to sell more than I need since I do not need the steering box or disc brakes.
thanks,
Robert
Hi Corey,
thanks,
Robert
It’s OEM off of my 69. The AM is on my 67. I’d probably make more on it all if I part it out. Scottsdale may be too far for you though.
68 SuperRam
04-29-2013, 08:47 AM
I have my 68 Subframe - sandblasted and powered coated. Never reassembled. I also have the upper and lower arms - powdercoated with new ball joints and urethane bushings. Also have a set of new powder coated silver front springs - SBC with A/C rated. I am in NY - near CT border.
bpatrol
04-29-2013, 06:57 PM
not mine but local for me in el paso
http://elpaso.en.craigslist.org/pts/3772456447.html
good luck
stealthjr
04-30-2013, 04:27 PM
good luck
Thanks...look like I found one and no longer need one now!
Nine Ball
05-07-2013, 03:08 PM
I have the stock front subframe from my '69 Camaro here in Houston. Clean, unrestored. Has all the suspension (SS 350 car) and steering attached. Contact me if interested.
Tony
Y-TRY
05-08-2013, 06:08 PM
I have one, in the Dallas area. It's not pretty but it's straight. You can email me at ytry68 @ aol.com. I had it on Craigslist. The only thing not stock are the Hotchkis tie rod sleeves. Has PST Super Kit, freshened A-arms, etc.
DD68SS
05-15-2013, 06:34 PM
i have stock frame with Detroit Speed Kit 3 Installed for sale
Blevinator
05-15-2013, 07:39 PM
I have one, 1968 Camaro
No rust, straight,dents on bottom where jacked up. You can buy a screaming performance jack plate (75.00) to fix large dent(also adds reinforcement plus twp two hidden tow hooks, fill,paint two small dents.
$ 250.00 san antonio tx
NvrDun71
06-25-2013, 04:06 PM
In Houston as well, how much? PM if need be, Thanks-
