View Full Version : vintage wheel works with bolt on valve stem issue?
brownz
04-19-2013, 10:37 AM
I have a vintage wheel works v40 in 18's and would like to know if this is normal for bolt on valve stems to have a gap on the washer. Not sure if I need to trim on side so that it sits flush.
Anyone else see this before?
killer69
04-20-2013, 07:39 AM
There should be a rubber gasket between the rim and the washer on BOTH sides.
CarlC
04-20-2013, 08:02 AM
I did not see my tire shop mount up mine, but they said the same thing. They used a standard rubber valve instead.
brownz
04-20-2013, 11:38 AM
The stems do come with two rubber pieces but they are intended for two different valve stem hole sizes. Or at least that's what I think.
killer69
04-22-2013, 12:29 PM
then call the manufacturer
AndrewNTX
04-22-2013, 05:59 PM
Besides the concern w/ the stem, can we see a pic of the entire wheel? what size/backspace, etc, did you get? Looks like you maximized the backspace judging by where the center is sitting on the barrel, from the little close up pic, the wheel looks nice!
Bryce
04-23-2013, 07:44 AM
I had a similar issue with my centerline wheels. I modified them to fit. I also have rubber on both sides.
brownz
04-23-2013, 05:24 PM
This is the best I have right now for a pic. The wheels are 18x9.5 front with 5.75bs and the rears are 18x11 with 7.75bs. I will be running a stock width rear. Trying to change it up a little from the deep lip look. I really like that look and that's why I did it on my Camaro but with these going on my budget build it made sense to save money
I will prob just run rubber stems to make it easy
AndrewNTX
04-23-2013, 05:40 PM
Wow they are beautiful, and the flat caps look great!
brownz
04-24-2013, 05:10 AM
Thanks.
