View Full Version : How can I use C5,C6 brakes with RideTech Tru Turn?
medbali76
04-19-2013, 12:27 AM
I bought a 70 Nova and it's time to start thinking on the upgrades I would like to make on it.
I would like to use the RideTech suspension kit with Tru Turn but I want to use C5 or C6 calipers also. Is there any conversion kit for the Corvette disc brakes on the market that works with the RideTech spindle?
csouth
04-19-2013, 04:38 AM
Since the site says you can use aftermarket or OEM disc designed for your vehicle, seems like you would only need a conversion bracket and hubs like the ones Tobin sells at Kore3.
Bad94
04-19-2013, 08:58 AM
I have C5 front brakes with the tru turn.
medbali76
04-19-2013, 10:19 AM
How did you install the discs and the calipers? Kore3 parts?
Bad94
04-20-2013, 11:10 AM
Yes i have a kore 3 kit.
brownz
04-24-2013, 05:23 PM
Call tobin at kore3 I have the tru trn for my nova and his brackets work with that kit. The only thing that you have to keep in mind is you will need to brackets for a disc spindle not drum. But your phone call with tobin will lead you in the right direction.
medbali76
04-26-2013, 10:39 PM
Ok, thanks!
