View Full Version : Can I fit 18 or 19x10 wheels on 68 without tub?
growngrass
04-18-2013, 03:46 PM
Curious if anyone has fit an 18x10 or 19x10 wheel on the rear of a 68 Camaro with no tub? Looking at 18x8 for fronts. Seen some pretty sweet pics of the 18/19 combo, but haven't seen if they were tubbed or not. Any pics would be appreciated as well as a backspace for front and back to make it look right. Thanks again!
68lovebuzz
04-21-2013, 12:23 AM
Running 19 by 9 on the rears of my 68. 10's are too big for a stock tub. If it were a 69 you could get away with it. You should have no problem with the fronts though.
68lovebuzz
04-21-2013, 12:28 AM
I'm pretty sure I ran 3.5" BS on the rear. That's due to 1.5" shortening of the axle per side. So that equates to 5" BS (with normal 10/12 bolt) on 9" wheel with and its damn near perfect on well side and lip side.
rfalker1
04-21-2013, 08:22 AM
I running 18x9.5 on mines and they fit like a glove... u might be able to do 10's but u will have roll ur fender lips for sure and probably have to worry about tire size as well
bonspeedbrad
04-21-2013, 04:21 PM
It is tight on the 67-68 Camaro but you can do it. You will give up tire and lip to get the 10 under the car. A 69 is no problem however.
growngrass
04-25-2013, 01:44 PM
Thanks Brad,
Could you shoot me some prices on Bonspeed Huntingtons?
