View Full Version : ridetech 4 link-does anyone make tail pipes for this?
ragtop1968rs
04-17-2013, 06:12 AM
My 4 link is on its way. Anybody sell tail pipes that fit with it? Thanks
67rstbkt
04-18-2013, 07:21 AM
From the instructions:
For the exhaust you can
either install a turndown or reroute the
exhaust under the axle. Stainless
Works makes a tail pipe specific for use
with the AirBar. 1-800-878-3635
130fe
04-18-2013, 09:35 AM
I would contact Stainless Works. I know a prior vendor used to ship them from there.
KINGZ28502
04-18-2013, 07:25 PM
The ones I got from the "prior" vendor don't fit because of the rear sway bar and as most of you know that vendor is of no help anymore,
thanks for the tip, I'll call Stainless works and see if they might help.
ragtop1968rs
04-19-2013, 05:35 AM
Anyone have a part number for these? I don't see them on their web site.
Josh@Ridetech
04-19-2013, 07:42 AM
They do have a kit for the Camaro AirBar, give them a call, they'll be able to set you up.
ragtop1968rs
04-19-2013, 09:41 AM
I just talked to SW and they do not sell the tail pipes sepetate. They just have a complete 2.5" system for $1090. I'm thinking I would be better off buying a magnaflow kit for $600 and having some tail pipes custom bent for it.
marolf101x
04-19-2013, 11:47 AM
No two cars are the same, so I prefer the "build your own" kits (available from Flowmaster and the like).
You know, the kind that comes with a bunch of bends and you cut and fit making whatever you want.
Allows me to assemble something that fits tighter to the floor providing more ground clearance, and provides proper clearance around all the parts (drive shaft, rear end, shocks, fuel tank, etc).
BayouSS
04-19-2013, 11:53 AM
I have the 3" Magnaflow exhaust on my Nova and really like how it fits and exits behind the tires. I have a RideTech Bolt On 4 Link (Thanks to Scott Mock) to install and was worried about the tailpipe clearance issues but when the time comes to install it I was just going to buy some various 3" SS tubing fittings and slice and dice the existing tail pipe until it fits. Or if that does not work just dump it under the axle.
makoshark
04-24-2013, 03:43 AM
This is something I, too, have to address on my 67 Camaro with Ridetech Airbar and magnaflow full exhaust kit. I want stainless tail pipes just like the rest of the exhaust system and do not want a bunch of weld joints in the tailpipes.
MonzaRacer
04-30-2013, 01:37 PM
As for me I will buy mandrel bends off ebay and work out my own stuff over the axle. Then pull it out and tig it up with my little thermal arc tig welder.
Quickboat
04-30-2013, 05:51 PM
What he said...
