View Full Version : Ideas for my bbc build....
67RSSS502
04-14-2013, 03:52 PM
So I am starting to get serious about getting my power train together.... Had the motor that was in the car taken apart and inspected....
Cylinder heads--
14097088 casting #
1991-up, cast iron, rectangular intake port, square exhaust port, 118cc open chamber, 325cc intake volume. Gen V 454/502 HO
nothing special with these currently
Engine block--
10237300 casting #
1996-up, Gen VI, 4.466" bore 502
The bores will need to be moved out to +0.030 as measures confirm why there is slap until it got warm.
Some goals: street able, will be backed with anT400 / gvod, pump gas preferably, naturally aspirated, no fuel injection, low maintenance, reliability, longevity...looking for 600-700 hp at the crank. Primary use will be a Sat night cruiser, but still be able to play if/when time allows :). I have looked at the Pile Driver build from Hot Rod magazine, as an idea....but wondering what the experience on the board would say.
camrat68
04-15-2013, 07:31 AM
There's slap until it warms up because GM used low tension rings. I have the 12568778 502H.O. in my '68 Camaro. We dusted the bores and installed some decent rings, re-balanced the rotating assy and the slap and excessive oil use disappeared.
600-700 at the crank is possible but you'll need to bring the CR up from 8.75:1 to closer to 10.5:1. Much over that you'll be running special fuel.
I'm at 9.2:1 according to my engine builder with a mild Erson cam and unported Dart 325's and I'm right at 597hp level and it'll rev safely to 7200rpm. If you don't re-balance the rotating assy and go with a TH400/GV setup then stick with 3.55 to 3.73 rear gears. If you do re-ballance it go with 4.10's and you won't be sorry.
Jim
astroracer
04-15-2013, 07:40 AM
I just went through the 509 I am putting in my Astro. I went with Brodix ovalport 270 heads, an Erson Hyd. roller and we set the compression right at 10.5:1. With an Edelbrock RPM Airgap and an 850 Holley my builder is expecting 550 to 575 horse and around 650 lb/ft. With a 400/GV and 3:75's it should be a real nice street motor. I hope to get it drivable this summer.... If you want to talk to someone who knows his BBC's I can get you a number. :)
Mark
