View Full Version : 67 chevelle mini tubb question
Scarface
08-17-2005, 02:20 PM
Anyone have any idea on what it would take to mini tubb a 67 chevelle and put in a ladder bar setup
Ralph LoGrasso
08-17-2005, 02:25 PM
Should be a very similar process on a '67. http://65.18.219.5/forum/showthread.php?t=9748
USAZR1
08-17-2005, 04:42 PM
Anyone have any idea on what it would take to mini tub a 67 chevelle and put in a ladder bar setup
What size rear tire do you want to run? Why a ladder bar suspension?
Scarface
08-18-2005, 08:40 AM
Want have the option to run up to the same tire as a viper. I just decided the ladder bar setup because it is allot cheaper than a 4 link. What would you suggest
Travis B
08-18-2005, 09:36 AM
I would only do a ladder bar if you are interested in straight line performance only they will bind and cause al ot of headaces! A four link will give much better handling and driving characteristics than a ladder bar! Especially on the street.
USAZR1
08-18-2005, 10:44 AM
I agree with Travis. A four link would work better with what you're trying to do. On the minitub route,I'm not sure it will allow you to run Viper-spec rubber. To run a 335 or 345 tire,you're looking at a 12-13" wide rim width. I'm running a 335/35/17 tire(with some 365's waiting) on a 17x13 rim but my 69 has full tubs and narrowed frame rails.
Besides,you can fit a 10" rim and 295 tire on your 67,now. But,I like your thinking.
While on the subject,I cannot say I've ever seen an A-body minitubbed.
Has anyone ever seen one done?
derekf
08-18-2005, 05:26 PM
Bill Howell's GTO is minitubbed, I believe.
USAZR1
08-18-2005, 05:37 PM
What did he do about the frame?
derekf
08-18-2005, 05:46 PM
Chopped it up with an axe!
Check out the pics: http://www.prodigycustoms.com/Billsgto.asp
(figured Frank would prefer if I didn't directly link the pics)
gchandler
08-18-2005, 09:26 PM
HTH Centerdrive rear suspension will work with frame rails pinched as much as 3 inches per side.
http://www.hotrodstohell.net/cars_from_hell/dons_chevelle/
Scarface
08-19-2005, 07:42 AM
Any idea on what kind of backspacing I would need to run a 10 inch wheel that will tuck inside the fender with no rubbing
Thanks for everyones help on here
USAZR1
08-19-2005, 10:29 AM
A 10" wide wheel will need 5.5" backspacing. Nothing less.
kidreynolds
08-21-2005, 08:13 PM
Well thanks everyone for the info I think I am just going to go with a 10 inch rim for now until I save up enough for a 4 link setup
