View Full Version : Source for Pack-Con plugs
Skip Fix
04-14-2013, 07:32 AM
Trying to custom wire my PW and locks using some of the factory harness. I can find the male and female terminals but no blank plugs-anyone found a source? 2 cavity,3 cavity or 4 cavity.
EFI69Cam
04-14-2013, 09:03 AM
If you can find the pieces you need in here http://delphi.com/pdf/contact/brochures/DCS_GlobalCatalog.pdf you can search the part number on mouser.com. They have most of the common parts available in small quantities.
Skip Fix
04-15-2013, 06:02 AM
Delphi's online search stinks! But I'll give it a try. Tried looking at mouser they have some things.
The harness in the doors is good so I hate to pull them out then snake the new ones in after pulling kick panels-which are a pain to pull and then reseal so they don't leak. Alos hate to put their plugs off. Painless has a nice harness with relays for each motor direction but they use their own plug and a new door harness.
EFI69Cam
04-15-2013, 03:07 PM
Delphi's online search does stink. The link however is to a giant pdf of their entire catalog. Its much easier to find stuff in there.
Skip Fix
04-19-2013, 12:10 PM
Got some from Mouser male and female plastic plugs, and female terminals. Dorman actually has some of the terminals.
