View Full Version : Steering input shaft size
intocarss
04-13-2013, 06:51 PM
I know there's 13/16" & 3/4" input shaft sizes..Here's my deal
The box that's out of my 68 Camaro on the bottom of the picture is a 3/4" shaft. And the one on top has a smaller (maybe 5/8" or metric??) input shaft. The rag joint used in my car fits snug on the 3/4" shaft but fits loosely on the IROC shaft.
The box on the top (in pic) is a mid 80's HX IROC box. Other box is mid - early 70's box. the converstion rag joint I have only comes in 3/4". I've done a search and no mention of the smaller shaft or a 5/8"/metric rag joint ..
If I tighten the coupler bolt ALOT, it will crush the coupler so it grabs the shaft but that does not seem the correct way to do it. The OEM coupler from the 80's Camaro will NOT fit onto the 3/4" shaft (did that just for refrence) .. What am I missing here??
https://static1.pt-content.com/images/noimg.gif (http://s2.photobucket.com/user/real3/media/IMG_6129_zpsd6c82ce6.jpg.html)
04-13-2013, 11:27 PM
They do have 5/8" 36 spline.
do a spline count, I tried but your picture caused my eyes to cross then I spit up my Ensure and passed out.
a67
04-14-2013, 04:20 AM
To fit the newer box into your '68 need to use a rag joint from a '79 - '81 (or so) car. The GM part number is: 7826542. The pinch bolt part number is 7807271.
Also note that the steering box hydraulic fittings are Saginaw opposed to the inverted flare that the '68 uses.
Bob.
intocarss
04-14-2013, 10:51 AM
Thank you and I'm using AN fittings
