olpostchevy2
04-09-2013, 09:06 AM
way to much to list folks lot of time invested and complete track record of build and pics from start to the stage it is now ,TOGETHER FOR FITTMENT AND FIRST STAGE OF PRIMER .PROJECT CAR ALMOST READY FOR PAINT!!!!!!!!!
detroit speed front end complete with stainless ls headers all of the front end has had all welds dressed and casting flashing removed spindles have been contoured debured and smoothed up ,tie rod ends ,anything and everthing has been slicked up purchased bare from DSE has double adjustible shocks with resvoir canisters,1 stage of primer .
detroit speed wiper motor mounted inside car .firewall has been slicked up and welded up bare metal
anvil 100% carbon fiber hood
ringbrothers billet hinges
t-56 trans sfi blow proof bellhouseing
i didit stering column borgenson joints steering complete
wilwood clutch and master cyclinder
408 lsx motor callies crank and rods weisco pistons coated ,file fit rings ,ati damper .total engine airflow L-92 CNC HEADS ,10:5:1 COMP,DECK SQUARED ,LINE HONED WITH ARP STUDS,COATED OIL PUMP SCD,YELLOW TERRA ROCKERS,SMITH BROS PUSHRODS,FAST LSX 102 INTAKE ,BILLET 102 THROTTLE BODY ,TRUCK COILS ,STOCK LS3 INJECTORS, GM STARTER,WEGNAR MOTOR SPORTS FRONT RUNNER SETUP COMPLETE WITH A/C,POWER STEERING,140 AMP ALT ALL DONE IN BRUSHED FINISH.BRAND NEW NEVER FIRED
FESSLER BILLET TRUNK HINGES AND TAILIGHTS
all gm fenders,doors,2 new quarters complete under side of the car has been deburred slicked up factory framerails,door jambs welded up and smoothed no seems untouched the car has been on the rotissore and all welded up,drip rail removed cowl vent welded up ,custom dash with billet a/c vents double din dvd,nav pioneer head unit , modified tunnel for t-56 trans minni tubbed for 295/35/19 bfg kdw tires on a 10 inch wheel custom billet wheels 18x9 front
wilwood 12.9 rear disc,3.89 gear alum center section ,moser axles ,fab 9 rear,custom 4 bar setup rear sway bar not installed yet ,afco double adjustible shock with remote resvoirs,
ricks custom tank with rear filler behind tag bracket setup for LS ENGINE COMBo above AND AUTO CROSS BAFFLEING IN TANK
CUSTOM BILLET ALUM GRILLE,GM NOS HEADLIGHT BEZELS,
VINTAGE AIR GEN 2 COMPACT MOUNTED UNDER DASH WITH CONTROLLER FABBED IN DASH
NEW FRONT WINSHEILD ,ALL NOS FRONT AND BACK GLASS STAINLESS POLISHED WITH NO DINGS ,
LOT OF TIME SPENT ON THIS, OUT OF TIME TO FINISH CONSIDER SELLING IT 4 YR PROJECT [email protected] FOR QUESTIONS NO TIRE KICKERS PLEASE MAY CONSIDER TRADES 35,000.OBO all brand new parts no junk .
