View Full Version : 3rd gen camaro rear disc brakes on 70 chevelle
exlt1guy
09-06-2004, 03:40 PM
HI everyone just got onto the new boards, the site has a nice look to it. I was curious if anyone has used 3rd gen camaro rear disc brakes on a 70 Chevelle 10 bolt before, i was just seeing what options i have for rear disc, i'm already starting on the c5 brakes for the front, any info would be great
thanks, Justin
gmachinz
09-07-2004, 09:08 PM
Welcome, Justin! I thought about using them on my '78 Monte but instead decided against using the rear discs from those (a little on the small side at about 9" overall)-however, I did use a '90 Iroc Z 4-wheel disc package underhood with the booster, mc and prop. valve. I used a street rod kit for its simplicity and price for the rear and it uses 11.75" rotors. Anyway, if you want details on my design, drop me a line and I'll shoot you some pics!
[email protected] -Jabin
Zefhix
09-07-2004, 09:22 PM
If I'm not mistaken the rears off an LS1 Camaro will bolt right up to your 10blt...why the trouble of the 3rd gen.?
exlt1guy
09-09-2004, 12:54 PM
just had the other rearend here going to waste lol, if the ls1 stuff will bolt up too thats always good to know
thanks
Justin
68BNUT
09-09-2004, 01:24 PM
Im researching doing the same swap just on a 68 camaro for the rear just having trouble finding a machine shop that will turn the wheel hubs down for me!! Im about ready to just grab a grinder myself! :attn:
protour_chevelle
09-09-2004, 07:22 PM
Your seriously having trouble? Find a driveline shop. They'll turn em for you. If not a hydraulic shop.(one that makes actual rams).
I listed the ones that I had no questions asked. Driveline shop turned down the outside diameter and Hydraulic shop did my hubs.
-Matt
Zefhix
09-10-2004, 02:14 PM
thanks
Justin
Yup, the brakets and hardware from an LS1 Camaro/Firebird (98+) will bolt right up to your 10blt/12blt A-Body. If you want to be creative you can make the stock LS1 e-brake setup work or you can give this guy (http://home.comcast.net/~petelohr/einstyn1/einstyn-14.htm) a ring and pick up his very trick setup. :cool:
