View Full Version : Morris 3 Point Seat Belts-Headline??
Phillip_L
08-16-2005, 09:00 AM
I am trying to install a set of 3-point seat belts into a 1969 Camaro. The headliner has been replaced and this car does not have a factory shoulder belt (or it has been removed). Is there a easy way find the mounting points? Do I need to pull down the headliner to have a peak? How do you remove the headliner properly? I have no experience with interior work and I am afraid to just start removing stuff. I am not sure where the clips are, what is glued, etc.
Thanks.
Phillip
morrisclassic
08-16-2005, 05:27 PM
Phillip,
I hope you are putting in a set of our seatbelts.
Measure 9 inches from the quarter glass rubber
seal, then 1 1/2 " up on the sail panel is the first bolt.
The second bolt is 2 1/8 inches further back.
I hope this helps. If you have any more questions let us know.
Billy
Phillip_L
08-17-2005, 05:32 AM
Thanks for the reply. I can not find your website or phone number.
morrisclassic
08-17-2005, 05:30 PM
Philip,
Our web site is www.morrisclassicconcepts.com (http://www.morrisclassicconcepts.com),
Phone number is 864-987-0032. You can take the sail panel out and feel behind it to locate the mounting holes.If you need anymore help call us, we'll be glad to help.
Thank You, Billy
Phillip_L
08-19-2005, 06:18 AM
You're directions were perfect. They bolted right up. Hopefully, I never find out if they work.
Phillip
morrisclassic
08-19-2005, 06:50 AM
Philip,
Glad to help. Thank You for your purchase.
Did you look at our other parts at www.morrisclassicconcepts.com (http://www.morrisclassicconcepts.com) ?
Thanks Again, Billy & Robin
