View Full Version : Perfect Back Space for 1967 chevelle ?
lsxoo7
03-29-2013, 10:45 AM
hang with me this might get long .
simple question what is the perfect back space for a 1967 chevelle with stock wheel wells with stock 67 rear end measurments in a 20x10 with a 285/30/20 rear size wheel/tire combo >? perfect as exactly centered in the wheel well , from measuring look like almost 13" of space and the 20x10 will be a little over 11"
5.5
5.75
or 6" or somewhere in between , car is sitting on ridetech air ride and would like the lowest ride possible with out having inner or outer fender interfierence .
anyone have pictures with with a 1967 chevelle with any of the 3 back spaces ?
have to figure out what the perfect back space would be so i can subtract backspacing from the wheel and subtract inches of the housing to make the wheel fit in the same position as it would have in a stock rear with a 20x10 with either 5.5 5.75 or 6" backspace .
plans are a billet specialties 20x10 with a 3.25 back space
and a chris alston FAB9 cut down either -2 ,-2.25 or a 2.5" depending on perfect stock backspacing on a stock 67 rear end .
thanks pictures are welcome of clearance and stance with any of the 3 backspaces , aiming for the biggest lip on a 10" and stock wheel wells .
novajess1972
03-30-2013, 03:37 AM
I had a 67 El Camino and a 70 Chevelle and currently own a 72 Chevelle. These cars may be different in the rear somewhat, but I have been successful each time running 10 inches in the rear of all using 6 inch BS.
lsxoo7
03-30-2013, 06:12 AM
How much clearance did u have with 6" bs ?
Where were u closer to ? Inner fender/frame rail out outer fender and inner lip ?
novajess1972
03-30-2013, 06:46 AM
Didn't do any official measurements, but I'd say there's about a half to 3/4 inch between tire and inner/frame rail and a good 3/4 to 1 inch between tire and inner fender. I will try and find the pics I took after installing wheels and tires.
lsxoo7
03-30-2013, 08:35 AM
So maybe a 5.75 back space would be perfectly centered ?
novajess1972
03-30-2013, 09:10 AM
Of course, every vehicle is different in some way. Even all a bodies, but I would imagine 5.75 should be good to go.
lsxoo7
03-30-2013, 11:36 AM
Anyone have a detailed picture of a 5.75 bs or 6bs On a 10" wide 20" wheel ??
lsxoo7
04-01-2013, 11:50 AM
Anyone have any input? I believe a 5.75 back space would work out perfect . The car is on air ride and will sit low down want the wheel lip too close to the outer inside lip
lsxoo7
04-09-2013, 05:32 PM
No one has a Chevelle with 20" wheels ? Lol
lsxoo7
04-20-2013, 05:07 PM
Anyone with a 20x10" with a 5.75 bs in a Chevelle ? Anyone almost willing to pay for pictures !
