View Full Version : What size bore master cylinder for C5 front/98-04 F body rear calipers/rotors?
uraceulose
03-26-2013, 06:07 PM
Guys,
I'm going to give the manual setup a shot and see how I like the feel vs. the hydroboost. At the moment I'm running a stock 69 Camaro master cylinder with distribution block underneath then back down to a proportioning valve on the frame rail. If memory serves it's a 1 1/16 or 1 1/8th inch bore in the master I'm currently running (this is with a hydroboost mind you).
13 inch front C5 rotors with C5 PBR calibers and 12 inch 98-04 F body rear calipers/rotors.
Just needing to know if I should go with a 7/8 or 15/16ths or what?
Thanks so much for any advice,
Donnie
Apogee
03-27-2013, 07:16 AM
I prefer the 7/8" bore MC in combination with a "GG" friction rated pad like the Hawk HP Plus, EBC Yellowstuff, etc.
Tobin
KORE3
Randy67
03-27-2013, 08:16 AM
I ran a 1" Corvette manual master on my 67 El Camino with C5 front and 98-02 F-body rears and Hawk HP Plus pads. It performed pretty good but the pedal effort was a bit high, so I would go with Tobin's recommendation.
Apogee
03-28-2013, 08:04 AM
Just for reference, running a 7/8" bore unit instead of the 1" noted above by Randy would result in about a 25% increase in output pressure for a given pedal input force, along with 25% more pedal travel.
Tobin
KORE3
Quickboat
03-28-2013, 09:03 AM
nevermind
