brgarris
03-24-2013, 08:10 AM
I have a stock 1969 camaro front subframe with the detroit speed stage II kit installed. The kit basically kits rid of all the stock brackets and has a jig to help relocate the new upper control arm mounting and shock brackets using the frame mount holes. I am currently trying to adjust the front suspension with the coilover shocks and cannot get it to drop enough. DSE told me that I would have enough adjustment to put the front end on the ground. I am running a LS3 engine and the spring provided by DSE are 10" 550#/in which on their website refers to a SBC or LS.
I am wondering if anyone else has encountered similar issues with the DSE front end kit on a stock 1969 camaro subframe? Also, to adjust the shocks you must remove the tie rod and sway bar connections and then loosen the lower ball joint just to get the shock out to make the adjustments. This is because when the shock is installed, the adjustment ring is up inside the subframe. This seems backwards to me, but it is the guidance that was given by DSE. To lower the front suspension you must loosen the adjustment ring and by doing so it move towards the upper shock mount relative to the shock. The adjustment ring will either contact the newly welded in bracket or the small spring pocket provided in the kit.
Any help you all can provide will be great!!!! thanks.....
