View Full Version : pictures of first gen camaros with ls1 turbo swaps?
darkostoj
03-20-2013, 03:51 PM
I'm not sure if its the right section or not, but i'm just looking for some different ideas on how to fab up my setup.
I got a 67 camaro I just put a LS engine into and just got done mounting the intercooler, was wondering what people did with setting up the turbo's
thanks!
joejaze
03-21-2013, 04:56 AM
https://www.pro-touring.com/showthread.php?48593-Project-Kaizen&highlight=kaizen
LS1NOVA
03-22-2013, 05:51 PM
Ive done several kits for Camaro's and 3rd gen Nova's. The basics are you take a pair of LS truck manifolds and chop and cut them, add some sch10 pipe as needed, and weld some vbands to the ends. A Trailblazer manifold fits the left side a little better around the steering shaft. I angle mill the flange 5.5degrees to get more clearance around the box. Make a crossover and add a wastegate after the merge. A single is easier due to the limited room for a downpipe around the steering box and column. If you have to run twins, run the manifolds upside down and chop them up to run forward. Yes, you could make headers for a little more bling but its hard to beat the durability of cast manifolds and they are pretty hidden when its together and spark plug access is stock like.
Here is my 71 Nova. This is the second turbo setup its had. I do all sorts of events with the car and I absolutely love the boost. It makes around 850 to the wheels.
https://static1.pt-content.com/images/pt/2013/03/Nova001-1.jpg
https://static1.pt-content.com/images/pt/2013/03/DynodayrandomCora021-1.jpg
Here is a single kit I did on my 69 Camaro mock up car.
https://static1.pt-content.com/images/pt/2013/03/69Camaro2_zpscc2cc9a0-1.jpg
And a pic of the left manifold.
https://static1.pt-content.com/images/pt/2013/03/071_zps17b81785-1.jpg
And the pair of manifolds.
https://static1.pt-content.com/images/pt/2013/03/075_zps3cab6b01-1.jpg
tyler qb
03-23-2013, 12:09 PM
http://calgary.kijiji.ca/c-cars-vehicles-classic-cars-1969-Camaro-6-speed-LSX-700-hp-turbo-W0QQAdIdZ465949093
LS1NOVA
03-23-2013, 12:18 PM
Here is another one I did this week with a Precison PT88.
https://static1.pt-content.com/images/pt/2013/03/70Novaturbokit027_zpsfd93b803-1.jpg
Todd in Vancouver
03-23-2013, 02:44 PM
Very nice and this is on my list of future wants
darkostoj
03-23-2013, 02:46 PM
progress so far today, got the intercooler and oil cooler rouged up
awesome $250 ebay intercooler and a factory 98 range rover oil cooler i found sitting around
perks of owning a junkyard!
https://static1.pt-content.com/images/pt/2013/03/65xKcGv-1.jpg
LS1NOVA
03-24-2013, 07:58 AM
Make sure to use the absolute biggest radiator you can fit. With the oil cooler and intercooler out front, the air will be pretty warm by the time it goes though the radiator.
67CamNKC
03-26-2013, 03:52 PM
Nathan,
On a budget setup with the manifolds, what do you figure you have in the complete turbo setup? Is there a factory turbo you would use or do you prefer an aftermarket one?
This is something I want to do down the road and will start collecting parts. Your installs look really clean.
Subscribed.....
darkostoj
03-26-2013, 03:53 PM
it is not cheap at all
think up everything you could possibly ever need
then double it
Nathan,
Subscribed.....
67CamNKC
03-26-2013, 03:59 PM
I figured as much. I'm trying to get mine driving first, then phase 2 will be more power.
BigCees1
01-27-2026, 10:59 AM
Hello LS Nova. I'm looking for those manifolds you had on the 69 camaro turbo build. I wanted to know if you bought them or fabricated them yourself. Thanks for the info.
dhutton
01-27-2026, 02:26 PM
His last visit here was ten years ago…. Post number 3 explains how he made them.
