View Full Version : Something other than Plastic
Evldoer
03-20-2013, 12:58 AM
So its my turn to upgrade my car with some ls power. Whats not to like about them, right? Well its just not like me to do things the easy way. I just dont care for the plastic intakes that gm puts on these engines. Yes they work well, but I wanted something different.
Here is my story about wanting something other then plastic.
First, I am building an LQ9, started with a good low miles engine, picked up some L92 heads. Now to top it off we have to make some chips fly.
https://static1.pt-content.com/images/pt/2013/03/intake1_zpsc6156e90-1.jpg
So I started with a couple blocks of aluminum and proceeded make them a little lighter. After the chips settled, this is what I ended up with.
https://static1.pt-content.com/images/pt/2013/03/122_zps393c0b12-1.jpg
https://static1.pt-content.com/images/pt/2013/03/124_zps2b641208-1.jpg
I then machined some bells for the tops of the runners
https://static1.pt-content.com/images/pt/2013/03/125_zps010272f1-1.jpg
and welded them to some extruded tubing
https://static1.pt-content.com/images/pt/2013/03/128_zps036d846c-1.jpg
Next I welded the runners to the intake rails
https://static1.pt-content.com/images/pt/2013/03/131_zps4b655236-1.jpg
This is what the rails look like bolted to the engine.
https://static1.pt-content.com/images/pt/2013/03/138_zpsa7921073-1.jpg
https://static1.pt-content.com/images/pt/2013/03/141_zpsaa334d95-1.jpg
This shot shows the front throttle body mount that I machined. Wish I would have gotten a picture of it before I started welding on it.
https://static1.pt-content.com/images/pt/2013/03/148_zps2e145be9-1.jpg
Back side before I closed it up....
https://static1.pt-content.com/images/pt/2013/03/150_zpsf2b03045-1.jpg
Back side closed up
https://static1.pt-content.com/images/pt/2013/03/153_zpse3d010ed-1.jpg
And the front. I still have some work to do on it, I would like to touch up some of the welds yet.
https://static1.pt-content.com/images/pt/2013/03/151_zps7283770f-1.jpg
https://static1.pt-content.com/images/pt/2013/03/152_zpsca94d9d0-1.jpg
https://static1.pt-content.com/images/pt/2013/03/154_zpsfa05a9ac-1.jpg
And here is MY version of something other then plastic.:smoke:
I have alot to do to the car before this thing can be dropped in, work is slow but its getting there. I want to put a smoke machine to the intake to check for leaks, Im sure there are a few spots that need to be zapped.
rchaskin
03-20-2013, 04:08 AM
Wow. Nice work.
I dig the mohawk!!!
cornfedbill
03-20-2013, 05:54 AM
Wow, I am impressed!
Barrrf
03-20-2013, 05:59 AM
Sweeeeeeeeeet
Sup with the "mohawk" as rchaskin noted?
Evldoer
03-20-2013, 03:45 PM
Sweeeeeeeeeet
Just something to set it apart from the rest, and make it mine
