View Full Version : rear shortening with g-bar
craigs73
03-16-2013, 08:54 AM
i have the g-bar setup for rear suspension.....as of right now im planning on just bolting the lower two bars to the stock spring perch pads on the axles...but the problem is i had a brain fart early in this build when i bought the wheels before i measured (remember first project)and im thinking im not going to be able to shorten the axles between the end flange on the axle and the stock mounting pad for the leafs... its looking like im going to need to shorten the axles 2" per side..so i guess my question(s) is will there be enough room between end of axle and the leaf pad to cut out 2" if not then how will i need to shorten the rear and still use the g-bar?
srh3trinity
03-16-2013, 09:43 AM
Ridetech makes a bracket that you can cut off the spring perch and weld on. The second chance camaro thread shows the brackets and how marty offset his arms for 335 tires. See if that helps.
brownz
03-17-2013, 06:19 AM
You will need to offest the lower bars and get the weld on brackets for the rear axle tube. You will not have enough room between the leaf pad to bolt you brakes up. Ride Tech sells the weld on bracket and also only offers the offset lower bars now
craigs73
03-17-2013, 05:55 PM
thanks guys i will look into this....brandon where in ohio are you from again?
brownz
03-17-2013, 06:42 PM
Im in west chester, butler county
craigs73
03-18-2013, 08:09 PM
not to far from me brandon like hour to hour and half.... i live in washington court house......be cool to see your cars some time
brownz
03-19-2013, 01:02 PM
Just let me know. yeah not far at all
craigs73
03-19-2013, 02:21 PM
There any events in ohio your going to do this yr
Quickboat
03-19-2013, 02:29 PM
Since the ride tech lower bars come offset, should the weld in lower brackets also be moved inward a touch from the stock spring perch centers?
brownz
03-19-2013, 02:35 PM
Yep going to try and have my nova done so I can run it sat and then bring the camaro up on super sunday. I wish they would let me in all weekend with the camaro. Grrrrr
craigs73
03-19-2013, 08:29 PM
i take it your talking about goodguys
brownz
03-20-2013, 06:38 AM
Yep good guys Columbus
Quickboat
03-20-2013, 06:52 AM
I was so looking forward to GoodGuys. But my wife has a wedding in Pittsburg we have to attend that weekend....GRRRR!
