View Full Version : Lq4/9 vs 383 Budget Swap
Oakesters
03-09-2013, 01:09 PM
I'm looking for budget engine swap for 1967 camaro. My budget is 4-5k and I'm looking at lq4/9 or 383 sbc. I has a muncie M20 4 speed that i want keep. Plans for the car are a weekend and fun car. Whats the total cost for the lq4/9 swap ? Thanks Ron
Todd in Vancouver
03-09-2013, 05:00 PM
I saw a posting for a 377 SBC for sale that may fit your goals perfectly. Have a look and see if it will do the trick. IMHO I don't know if you can get a decent LS into your car for that price.
garys 68
03-10-2013, 04:21 AM
This is the budget build for my 72 cutlass. It was a 5.3 with a Muncie, a 6.0 will be a few bucks more.
Be sure to get everything with the motor, harness, TAC, pedal, fuel pump, accessories, etc
05 5.3L L56 (LM7) 50k miles $900
I changed LS1 intake intake/ aftermarket fuel rail (not necessary) $150
CTS-V oil pan (not necessary, but good for ground clearance) $140
Sachs 1050 flwheel/11" 10 spline clutch/621 bell housing/etc $350
Fans/controller $60
F body exhaust/flanges $110 (still need mufler shop to make downpipes)
ECU reprogram $75
VSS $35
tank, pump, regulator, fuel lines, etc $350
1" setback mounts $60
Misc, wiring connectors, fittings, etc $100
garys 68
03-10-2013, 04:22 AM
duplicate
rocketrod
03-10-2013, 04:46 AM
Read this thread on LS1tech concerning budget LS swaps http://ls1tech.com/forums/conversions-hybrids/1075693-my-budget-ls-engine-swap-guide-1500-a.html
Oakesters
03-20-2013, 10:35 AM
What are people spending on 6.0 swap? Just the engine? OAkesters
cornfedbill
03-20-2013, 10:47 AM
I built a 377 carburated motor on a budget. I swapped parts and labor for a lot of the parts I used.
If I had to do it all over again, I would go the LS/LQ route. More bang for the buck. It is also a lot lighter than my iron block/iron head motor.
In my opinion I think you will be glad you did in the end.
67rally
03-20-2013, 05:17 PM
Depends on the mileage. For a full drop out, with all accessories, harness, pedal, ecu, etc. $1400-2200ish. LQ9 will go for a couple hundred more than an LQ4. 50,000 miles will be on the higher end of the pricing, 125,000 miles will be on the lower end. For a long block without the accessories or harness, you can probably cut $300-500 off the price.
Then there are all the extras. You may not be happy with the truck intake and opt for an LS6 intake ($300), or accessory layout and need new brackets ($250-400). You'll need new headers ($600-1200), you'll need to mod the wiring harness ($250), or buy a custom one ($500). If you're current setup is carbed, you'll need a new tank and fuel pump ($500-1000), and new fuel lines and fittings...You'll need an adapter for your transmission, or like me you'll buy a whole new tranny $$$$$$. You may need new gauges? Radiator? Hoses? You'll definitely need new motor mounts...
I'm in the process of swapping an LQ9 into my '67 Camaro and the costs add up fast. I started with a generous budget, and I'll be double that by the time it's done. It'll be worth it, but you need to do your research first.
Tom Welch
03-21-2013, 08:03 PM
my 67 firebird lq4 swap is WAY more expensive than a small block build. i could buy a new 383 from the local chevy dealer for less, much less.
SparkyRnD
03-22-2013, 12:25 PM
We can help you with the radiator part ;-)
youre trans and bellhousing boltup to the LQ4 engine, get the edelbrock LS carb intake $265 bucks, the MSD 6010 ignition box $325 bucks, transdapt adaptor mounts $50 bucks, Truck LS flywheel from rockauto $65 bucks, and sanderson LS swap headers $250 bucks, use youre old carb the swap is cheap this way and what ever you want to use for an oil pan, I used the moroso pan for $250 bucks
