View Full Version : LY6/6l90, KWIK performance, stand alone harness, Turbonetics 72mm
SShep71
03-08-2013, 09:23 AM
So I want to see how much interest there is in this combo. I am thinking about selling my setup and going with a different setup. If anyone out there is interested let me know and maybe we can work something out. I am asking under what I have in it 5500.00. The engine is out of 07 Silverado that was rolled over. The motor is fine. I did a compression test and it checks out perfect. I did a check under the valve cover and it is super clean. The trans is out of the same truck, it is just as clean as the engine. I checked the fluid and it is perfect. I also have a brand new 72mm Turbonetics hurricane turbo, it was only out of the box for pictures. It is the ball bearing turbo. I am asking 700.00, retail is 850.00 All the stuff is in climate controlled storage right now. I can ship!
What I have:
-07 LY6/6l90 removed from a Silverado with 7k miles on it, the engine is in awesome shape, with all accessories on it including exh manifolds, starter, and AC compressor w/lines.
-07 6l90 D-code trans with converter. The pan was pulled and the oil/filter is spotless
-Camaro LS3 intake with stock 53lb injectors and new stainless steel bolts. The intake and injectors have only 50 miles on them
-Stock truck intake manifold, with stock inectors, and throttle body
-Stand alone 3-wire hook up wire harness/ with wiring diagrams
-Kwik performance alternator bracket kit pn: K10163
-Kwik performance power steering bracket pn:K10168
-Kwik performance power steering pump w/pulley installed
-Gates pulley pn: 38006
-Gates pulley pn: 38012
-GM Idler pn: 12560344
Like I said, its up for grabs. If you are interested let me know.
coachwinbush
03-08-2013, 12:14 PM
Is the transmission for sale pm me
SShep71
03-08-2013, 12:40 PM
The whole thing is for sale. I wont separate. The only thing available separate is the turbo
moreHP
03-08-2013, 01:41 PM
PM box is full!
SShep71
03-09-2013, 02:42 AM
Inbox is cleared out
SShep71
04-05-2013, 09:29 PM
Bump
coachwinbush
05-16-2013, 06:12 AM
if its a 6l90 ill take it
SShep71
05-17-2013, 08:00 AM
If anyone is interested I am in California on leave until the 30th. I can show the setup at anytime just let me know. After these two weeks it is going to wait until Christmas time when I will be home again. It is a low millage super clean 6L90.
andrewb70
05-17-2013, 05:43 PM
Any more details on the turbo? Is it the 7268? T4? What the AR on the turbine side?
SShep71
06-17-2013, 02:16 PM
No longer for sale!
