View Full Version : 5 on 4.5 bolt pattern on a GM
67rstbkt
03-04-2013, 01:38 PM
Might be a dumb question, but here it goes. I'm going with a Ford 9 for my rear-end. Any reason why I should not go with the Ford wheel bolt pattern (5 on 4.5, correct?) on the rear and GM pattern on Front? Rears will be wider anyways.
Sean Cooke
03-04-2013, 01:44 PM
Your wheels will have to be two different bolt patterns
67rstbkt
03-04-2013, 01:46 PM
I figured that, but it would not matter since the rears will be wider. I did think of an issue since I posted; I would run into issues with using GM Brakes if I did this. I guess it's probably best to stick with the GM pattern
Alex's 1970
03-04-2013, 02:06 PM
well if u diced to go with a 5 x 4.5 on the back and 5 x 4 3/4 on front I have a set of wheels that am going to sell. if it interests you the are 17 x 8 and 17 x 9 1/2 torq thrust ll .
67rstbkt
03-04-2013, 02:08 PM
Appreciate that, but I don't think they would fit over C5 brakes
Chris02rex
03-04-2013, 02:21 PM
I just had my axles re drilled on the ford 8.8. I think it only cost like 70$. Worth it to me.
astroracer
03-04-2013, 03:46 PM
I'm running 17x10's on the front of the van. No C5 brake clearance issues other then the Bonspeeds have the fill valve "behind" the spokes so I have to go with a shorter valve.
67rstbkt
03-04-2013, 07:45 PM
Just depends on the 17, I really wanted the Year One RallyII replicas, but turns out they do not have that much room on the inside
csouth
03-06-2013, 08:28 AM
The issue with with brake clearance wouldn't be a matter of bolt pattern, either they will clear or they won't. I would personally stick to the same bolt pattern all the way around, but I've heard of it being done before.
67rstbkt
03-06-2013, 08:46 AM
Well that, and the GM brake rotor would have to be drilled for the Ford pattern. I think I'm just going to stick with the same GM pattern all around. I'll either get the axles re-drilled or buy new ones. Thanks
