View Full Version : Fays2 Watts Link for 68-72 Chevelle. Is anyone running it and how do you like it?
626Chevelle
03-02-2013, 05:28 PM
Im interested in the Fays2 Watts link for the 68-72 Chevelle, but not sure if its worth the price. Is anyone out there using, and if so how do you like it? What are the differences with and with out the link? Is it somoething you can do without or regret buying? I want to hear from someone thats using it. Most people explain how it works and what it does, but are not running it. And if they are running it, they are using it on a newer type mustang. Im talking to the A bodys on this one.
James
GRNOVA
03-02-2013, 06:03 PM
I am running one on my 65 Nova. From what I can till you is it really let me get the car where I wanted it and handles great i can throw it into the corners without the fear of anything letting loose really keeps the tires planted.
http://s300.beta.photobucket.com/user/tnt342/media/65%20nova/DSCN1596.mp4.html
626Chevelle
03-02-2013, 11:37 PM
That's what I wanted to hear. Thanks
If there's anyone else, please let me know your experiences with it.
Sean Cooke
03-03-2013, 12:13 AM
Let me know what you come up with, my setup doesn't really allow for a sway bar right now so I'm interested in one too
626Chevelle
03-03-2013, 01:05 AM
Why is it not set up for a rear sway bar?
neki67
03-03-2013, 09:36 AM
A Watts link has a totally different purpose than a sway bar.
chevelletiger
03-03-2013, 12:59 PM
try to pm jon(roadbuster) he has one on a orange 68 gto.one thing it worked well with is he's running an 11" rear rim with 315 35 18 tires,no frame mods or mini tubs just a little massage to some areas on the inner wheel house and it help with not letting his tires rub,but you do need to make a tank for the watts or use a nova tank,which im modding now for my watts i made from scratch from looking at jons.the nova tank is not as deep as the stock abody tank.phil
chevelletiger
03-03-2013, 01:04 PM
i think its because how sean has his coil over set up on his rearend.
camaro427-69
03-03-2013, 11:07 PM
hmmm had one in my 69 camaro and it made the car handle wayyyyy better. when i was hitting a bump the rear was starting to swing slight left right which gave you a awkward and not so safe feeling and the same on fast short turns and that was all gone with the fays2. worth the Money and would buy it again? definitely yes! the only turndown is the Routing of the exhaust if you want rear exit and that took me some time and welding to get the 3" stainless exhaust around and not bumbing anywhere and i´m running only 255 tires in the back so there´s lot more Routing space back there.
GRNOVA
03-04-2013, 05:49 AM
I was going to run the exhaust under the rear and mount it to the frame of the watts link!
camaro427-69
03-04-2013, 06:17 AM
hey tim i hope it works out for you the first time cause it took me 3 tries :)
GRNOVA
03-04-2013, 07:11 AM
I think I need to look at yours and maybe rethink things!
neki67
03-04-2013, 09:25 AM
Tim, nice idea but it won't work since the lower link and propeller will be in the way on the right side. Unless you want to hang the exhaust really low and it will already be low enough when you mount it nearly direct to the W.L. frame.
camaro427-69
03-04-2013, 01:46 PM
tough to route on passenger side, driver is pretty easy cause the arm is Mount low to the leaf perch but the passenger goes right on the upper side almost all the way over to the leaf mount. Need to check if i got some better Pictures but i bet here´s People with nicer built cars and not rotten like mine :smoke:
72247
rustomatic
03-05-2013, 09:20 PM
Tons of vintage roadracers (especially Mustangs) use them. Just Google...
GRNOVA
03-06-2013, 05:41 AM
I should be able to squeeze the exhaust under here the suspension is hanging at its lowest point!
626Chevelle
03-08-2013, 08:18 PM
Thanks everybody for the info.
