View Full Version : Need help deciding what brake booster n mastercylinder to match with baer ss4+ brakes
71FORDREAPER
03-01-2013, 08:45 PM
Does anyone know a good brake booster and master cylinder to support a pro-touring 800+hp 71 chevelle with baer ss4+ brakes? Looking for something that clean/chrome, small, but works very well? Any help will be appreciated. Thanks
Apogee
03-02-2013, 01:55 PM
Vacuum booster and 800+HP probably don't belong in the same sentence since I'm assuming your vacuum levels at idle are going to be less than conducive to such a configuration. Additionally, small vucuum boosters generate small levels of boost, so they're also not likely to work well in an application starting with suspect vacuum levels. If you want power brakes and have power steering, I would suggest you contact Paul at Hydratech for a hydroboost solution, otherwise have you considered manual?
Tobin
KORE3
BlackPearl
03-03-2013, 07:32 PM
You can check out these folks also at ABS http://www.abspowerbrake.com/
