dusterbd13
02-22-2013, 09:23 AM
so im building my 64 el camino.....
plans are a compenatnt dailoy driver. not planning autocross or open track, i have the duster for that.
the suspension is slap work out, with some scary characteristics. wheels will be 17X9.5 with 275/40/17 tires. brakes will be corvette 4 wheel disc.
power steering will be a jeep grand cherokee 12:1 fast ratio firm feel box.
on the front suspension, i have a huge swaybar (1.5 inch maybe?), and not much else. im thinking of boxing the LCA's, and going with some AFCO steel bushings. planned on running proforged tall upper ball joints, but unsure of what i need to do with the UCA's. i have a connection at UB machine that can make me a straight armed tube uca for ~50 each in whatever specs i need.
for the LBJ, im unsure wether or not to go with a tall lower. what are the camber gain specs either way? bumpsteer specs?
im thinking fo finding some bilsteins for thefront shocks as well. ride height will be set by making the LCA parallell with the ground. that way i can maximise negative camber gain with whatever i have.
on the rear, i really have no idea. thoughts are to box the control arms, and use poly bushings. but then ill have binding issues per internet research. i can jo with johnny jointed uppers and boxed lowers, and i think i can get where i want to be. whiat would you do and why?
im also planning on dropping the rear to where its level with the front, whatever drop amount that might be. i still need to e able to use it as a truck though, and ive seen where there are drag bags that go inside the springs. would thius work? ive also seen products that change the rear LCA angle tof traction, etc. so i need to go here?
so anyway, im looking for ultimate bang for the buck. sweat equity is free. money is tight. where would you spend it and why?
