View Full Version : Are there any vendors who can Water Jet or Laser Cut DSE Mini Tub Filler Pieces?
GeoffP
02-17-2013, 05:28 PM
Just like the title says, are there any vendors who can/will water jet or laser cut the filler pieces required to install the DSE tubs? I have access to a plasma cutter so I may end up doing it myself but I just thought I'd ask just in case the price is right.
Thanks in Advance!
makoshark
02-18-2013, 07:27 AM
I found, when doing my tubs, the templates weren't completely accurate to my car. Each car will vary as well as it also depends on where you make your cuts to the size of the templates. Once you get the old tubs cut out and ready to install the new tub, make templates then. I used 11 gauge sheet and cut them out with a plasma. My car was a 67, too, so that changed things with my install because the supplied templates were for the 68-9 models.
GeoffP
02-18-2013, 03:14 PM
Thanks - I think it's best to delay the tub install. The more I think about it the more I think it's just not doable with what I have to work with along with the time frame I need to complete the installation. I appreciate your input!
Vortech404
02-18-2013, 05:17 PM
GeoffP,
Chris Alston Chassisworks has the close out pieces for $99.00
https://www.cachassisworks.com/p-1819-camaro-67-69-sheetmetal-closeouts-for-mini-wheel-tubs.aspx
maybee those will work with the DSE tubs
John
DEIGuy38
02-19-2013, 10:24 PM
Thanks in Advance!
You can do it yourself. I did it for $20 bucks for the steel and a port a band saw, 4" piece of pipe and a hammer
GeoffP,
John
If you are scared to do it yourself this doesn't seem to bad for the steel.
makoshark
02-20-2013, 02:08 PM
I used the round part of a motor stand to shape the frame piece. Worked perfect
GeoffP
02-20-2013, 03:31 PM
That's a great suggestion - I will definitely have to remember that! Guys I decided to delay the tub install until after this season since I've got some other stuff that has to be done before DSE's event in April. Thanks for the suggestions!!
