MattG
02-17-2013, 08:31 AM
The cam you list has 19* of overlap and based on the type of driving you described, would be a poor choice. That is a much larger cam than you need and would not do well with low end torque and would be very peaky in power I think. There are tons of cams that would suit your needs, but the common theme is to keep the overlap much lower (in the 0-10* range) to aid in driveability. Even the best tuners out there would have a hard time getting your cam to be smooth to drive. Here is some good reading for you...
http://forums.corvetteforum.com/c6-tech-performance/2443505-spins-cam-being-dynod-right-now.html
Also, here is the website to calculate overlap: http://www.wallaceracing.com/overlap-calc.php
Hope this helps. I have a friend running the Spinmonster cam and it drives stock and is strong as hell. It was tuned by Ed Hutchings http://www.hitechtuning.com/ and he is one of the best tuners and really likes the cam also.
Matt
MattG
02-17-2013, 02:38 PM
I think I just had a conversation with myself. :cheers:
