Corey R.
02-12-2013, 08:14 AM
Has anyone heard of this company, or for that matter upgraded their drum brakes in a similar manner?
This kit states they use 31 lb springs and a high volume wheel cylinder compared to 13 lb stock springs.
I am in the middle of installing a new power disc conversion up front, and noticed the rear drums could use sprucing up as well. Large front and rear discs are not an option due to 15 inch wheels.
I'm not expecting C5 stopping power, but any improvement would be appreciated.
http://www.musclecarbrakes.com/bib6772camaro.html
Muscle Car Brakes all new Brake In A Box comes complete with both pair of High Performance Matrix Ceramic Disc Pads and Matrix Ceramic Brake Shoes, 31 LB Heavy Trick Spring Kit, Star Wheel Self Adjuster Combo Kit plus Rear High Volume Wheel Cylinders for less pedal pressure. In addition, Brake In A Box gives you a 2 to 1 better braking than OEM over the counter brakes. Brake In A Box is a direct replacement available for most pre-72 model GM, Ford & Chrysler cars and light trucks. Self adjusters may not be available on some older models.
