stinga
02-11-2013, 10:03 PM
Hi there guys, wondering if soemone here can impart some advice as I have searched high and low but really haven't come up with a good solution.
I have a Dart 598 tall deck big block with all the fruit in a 68 Camaro but you guessed it, hood clearance issues. I need to to try and reduce intake height by about 1.5 inches if poss as I do not want to go 4" cowl hood (currently have a 2"). Currently have:
Holley Dominator 1050
Edelbrock Super Victor CNC tall deck 2918 (6.95" height)
RHS heads ported and benchflowed 800hp
Engine Flywheel Dyno 738hp @ 5800rpm
Engine Torque 766Ft lb @ 4300rpm
Considering going to a Holley 950 DP with drop base airfilter and a new intake, but which one?? I know I will sacrifice power but torque curve should be shifted over to compensate. A RPM airgap with spacer will only save me about 1/2" at the dizzy end so other option is a Torker ll which will save me about 2".
What is the max power a Torker can make as I have read very conflicting data on these (I may be able to fit a spacer between Torker and carb if lucky to increase plenum volume). I cannot drop the motor any lower due to headers so if you have been there and have some advice I would really appreciate it. Or is there another intake option?? At the end of the day if i loose 100HP but torque comes in earlier I can live with it.
Cheers Lads
Al
Cheers Lads
Al
