View Full Version : 68 Camaro wheels & tire Size
davisgsxr06
02-08-2013, 02:14 PM
Does anybody know the biggest(as in width & height) tire that will fit in rear of 68 camaro(stock, no tubs) ,wheel size & back spacing needed??? Im running 20's on rear now but really looking to put a set of 18's all way around...
pollusky
10-21-2013, 12:51 AM
If you still looking for an answer hope this help
pollusky
10-21-2013, 12:52 AM
Photo 1
jonjonw
06-27-2016, 05:31 PM
Thanks for this photo. Much help.
67rally
06-28-2016, 09:25 AM
18x8's up front with 4.75"BS with 245/40/18
18x9's with 5.25"BS or 18x9.5 with 5.5"BS in the rear with 275/40/18
You may get lucky and be able to run even bigger tires, or be unlucky and have to go down a size, but the above sizes are generally the largest/widest you can go comfortably on a 67/68 1st gen.
Decline
06-28-2016, 10:37 AM
Use tirerack as a resource for tire size. They measure the tread width of each tire and post it in the specs section.
For instance this 265/35 18 RE-Z1r is 9.7" wide.
http://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Potenza+RE-71R&sidewall=Blackwall&partnum=635WR8RE71RXL&tab=Sizes
Ideally you'd want it +/- a half inch. This is the tire i plan to run and i have 9s in the front and 9.5s in the rear on my '69
