View Full Version : 1968 C10 LWB LQ4 6.0 swap - Indy $8000
Cannon
02-08-2013, 12:01 AM
71072
1968 Chevy C10 LWB Fleetside
Has a 2004 Chevy Silverado (http://indianapolis.craigslist.org/cto/3578970325.html#) SS 6.0L (364ci) engine professionaly swaped in by Mike Norris @ his shop and Dyno Tuned. - http://mikenorrismotorsports.com (http://mikenorrismotorsports.com/)
Only about 1500 miles on it since swap
Reason for selling: Too many projects and not enough time, money, space! Open for trades of complete vehicles as well. Make me an offer!
Dont mind the date on the pictures, I just didnt set the date on the camera, they are all from this years september.
71073
Engine mods:
224/228 .598/600 112 Mild Cam swap.
Nitrated Comp cam beehive valve springs good to .650 lift
7.4" Chromoly pushrods
Comp cams dual roller timing chain
Blue printed and ported LS6 high flow oil pump
Doug Thorley LSX swap long tube headers.
dual stainless steel Mangna flow exhaust with mendrel bent pipes.
Believed to have about 70k miles on the engine before swap.
Made 319RWHP/414RWTQ on chassis Dyno - have graph to prove as well.
71074
Chassis Mods:
New front and rear lowering springs and shocks 2/3"
New Totaly Tubular rear trailing arms and bushings
New adjustable track arm.
Practicaly new drum brakes and lines througout.
New LSX swap engine mounts
71075
Has a stock(not original from this truck) TH400 with a new 3k stall street/strip summit racing torque converter.
New Lokar cable mounted shifter w/Reverse lockout.
Stock 12Bolt posi rearend with 3.73 gears.
275/50/15 on all 4 corners
Power Steering but manual brakes.
No A/C or Heat. Have new heater core and can easily hook it up to new engine but I dont drive in winter.
Windshield wipers and lights work fine.
71076
Body is in great shape given its age. Very little rust and what rust there is, is only surface rust. No major dents either. solid and straight. Needs a paintjob though.
Made a few passes at IRP 1/4 mile strip and went a best of 13.6@98MPH on street tires!
Hooks up well and makes a smooth pass and brakes well after. Great street rod. Just needs some TLC and a bit more cash (http://indianapolis.craigslist.org/cto/3578970325.html#) to take it to the next level! Drives great as is though.
Also including new 3" rear lowering blocks. New Rear Chrome Bumper with brackets and new rollpan that are not installed so you can decide what you want.
Cannon
02-22-2013, 11:03 PM
Sold!
