chevnut55
01-31-2013, 06:09 AM
I just finished swaping my 69 camaro over to disc brakes using a mbm rear disc kit and factory style front with drilled/slotted rotors and braded hose and a new booster/master/prop valve. I guess I can sell everything to buy the parts I need to do the swap.
I ran into a great deal on 2000 corvette complete brake system and bought it.
I will be using the old drumb brake spindle and KORE3 adaptors.
The new master/booster prop will be swaped over to the c/5 set up.
the rear will be swaped over to the c5 disc/e brake.
I knoticed the rear back plate to axle is completly different, is there a way the back plate can be welded and drillet to fit the axle flange? or will I need to track down a f body set?
I know I need to get another caliper because of the staggered shocks ,on my last camaro I just moved the shock out 1" on the bracket..will this work on a 69 camaro too?
Should I use the c5 prop valve or elimante it and use a adjustabe valve?
and the brake hose, I know kore3 sells the adaptor lines but could I also just replace the lines with metric and eliminate fitting serching for the master/etc..?
